Home > For Sale > Unfinished Mini Project - Restored shell, New Running Gear
laundrymike
Member #: 506
Hard decision this, but I've decided to sell the following Mini. Having owned it for over 10 years, done all the hard work and spent in the region of £5/6000 getting it to it's current state.
Started life as a '82 Mayfair which was stripped and had all the usual panel replacement, plus double skinned floors, bulkheads sealed and roll cage installed. Was then fitted with brand new subframes and all new Cooper S brakes (Not reconditioned) Spax, Hi-Lo's, Rose Joints, Superfins, etc...custom one off wiring loom, all fuses/relays in custom centre console and brake/fuel lines routed inside the car.
All that's left to do is engine/gearbox (I do have a rebuilt 1293 MG lump aswell) interior and fuel/brake lines to plumb. Plus paint. Easy finish for the summer, as I say all the hard work has been done.
V5 Included aswell
Mini is located in North Yorkshire (I live in Belfast, and can arrange to have it shipped to NI if required?)
Lots of pics here: http://s152.photobucket.com/albums/s175/La...i%20For%20Sale/
Please email for full spec, far to extensive to list here!
Looking for £2,495 ovno...you will not be disappointed with this mini
Any questions, offers or advice then please get in touch...Cheers, Mike
laundrymike
Member #: 506
Anyone interested before I stick it on ebay??
Cheers, Mike
not given people chance to have much of a look! *happy*
but it seems a lot of money for a mini that doesnt drive.
unfortunately thats the problem with part finished projects. *frown*
laundrymike
Member #: 506
I hear what you're saying completely, just anxious to sell before I change my mind about doing so...again!! excuse my anxiousness - don't even think that's a word!?
I've spent twice what I've put it up for, if not more...what do you reckon it's worth? Bearing in mind the spec is extensive, will mail it if you wouldn't mind looking it over as I've been out of the mini 'scene' for a while now, however my guess is Minis are still rusting as fast as ever and for someone with a running car with shot bodywork and running gear, It doesn't get any better than what's sat in my garage surely...?!!
Cheers, Mike
put the spec you were going to email up on here, i'm sure it will be more than appreciated.
I can see your point about "re-shelling" someones car but its a lot of wedge to spend to splash out *smiley*
if you can get someone to think about it then it more than is worth it though.
laundrymike
Member #: 506
Body shell
Shell has been fitted with the following new panels:
- front panel
- both wings
- bonnet
- inner and outer A panels
- scuttle corners x 2
- doors x 2
- inner and outer sills
- rear valance
The floor pans have also been double skinned, both the front and rear bulkheads have been sealed, the rear companion boxes and the rear seat mounting brackets have also been removed. Box section strengthening has also been fitted between the door frames, rear quarters and the rear arches inside the boot.
Fuel, brake and battery lines have been run inside the car.
Wiring has been scratch built, with fuses, relays and cut off switches fitted in a custom centre console.
A Rollcentre 6 point cage has also been fitted, which will also take door bars if required.
New parts fitted:
- Laminated clear windscreen
- Wider windscreen seal
- Rear opening quarter lights
- Heated rear windscreen
- Headlamp rims
- Headlamp bowl assemblies
- Halogen headlamps
- Amber Indicator lamps
- Internal bonnet release kit
- Steering column height adjuster
- Chrome door handles
Reconditioned steering rack
Original:
- Pedal box
- Steering column
Front Subframe - NEW as are all the components
(GEN) subframe, shot blasted and powder coated red.
Alloy top mounts
Alloy rear solid mounts
Alloy teardrop front mounts
Complete Cooper ‘S’ 7.5” disc brake assembly with large CVs and pot joint drive shafts
Spax 40th Anniversary GSX adjustable dampers (Lowered)
Lowered shock absorber top brackets
Competition lowered shock absorber pins
Reconditioned top suspension arms
HiLo adjustable suspension trumpets
Rose jointed one piece lower arms
Adjustable heavy duty tie rods
Longer track rod ends
Braided brake hoses
Poly lower arm bushes
Rear Subframe - NEW as are all the components
(GEN) subframe, seam welded, towing eye added, shot blasted and powder coated red.
Poly subframe bushes
Reconditioned radius arms
Minifin alloy brake drums
Metro back plates
Braided brake hoses
KAD aluminum handbrake quadrants
Carl
Member #: 95
liverpool-on-sea
my advise would be spend a little more and get it finished then sell it, unfinished project sell for peanuts normally. put in the engine youve got put 12 mths mot on it. you should do ok (ish ) then
