| Home > General Chat > opinions on spray guns ??? | |||||||
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
16th Apr, 2007 at 07:34:04pm
ok now that i have my swanky compresser courtessy of Benross ! i am collecting air tools, i have the DA, an Air Cutter, ratchet. i have a lend of a spray gun which is ok, i used it to spray my block, but want my own for when i do me mk 1 shell.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
16th Apr, 2007 at 08:33:01pm
Sata have a very good rep and I know Roger is a fan of them, apparentlt there's a company out there who do very good knock off copies for a fair bit less than the Sata price.
16th Apr, 2007 at 08:36:30pm
Devilbliss if you can afford the wedge.. i used a clarke suction feed gun on my mini with good results. |
![]() 100 Posts Member #: 1426 Advanced Member Birstall, Yorkshire |
16th Apr, 2007 at 08:47:36pm
Ah American Hotrod.... What i would give for that workshop!
16th Apr, 2007 at 08:58:49pm
long story there ! it has sat in their compound since 28th March. no paint......went in today and kicked off a bit, guy says he will prep and prime this friday, then sat morning i will go into the booth with him and he will show me what to do. it has to be sprayed white first (roof is white) then rubbed back and the main body will be painted yellow the following day the white will be a base coat to brighten the yellow further. will take pics though.
16th Apr, 2007 at 09:13:05pm
gravity fed is the best rich,
Edited by BENROSS on 16th Apr, 2007.
16th Apr, 2007 at 09:14:05pm
Gravity fed devilbliss is great. Used crappy ones for primer etc On 19th Jan, 2010 wil_h said:
16th Apr, 2007 at 09:15:42pm
cool cheers. will give em a whirl.....if anyone sees one let me know, i will surf the bay and find one. i take it spares are readily available and 8nt too expensive.
17th Apr, 2007 at 12:09:20am
I do indeed like my Sata guns .... but then again the guy who trained me used them so it's what I got used to.
17th Apr, 2007 at 12:16:00am
superb! roger
17th Apr, 2007 at 12:28:16am
Steve,
17th Apr, 2007 at 10:14:51am
hahahaha. Steve will my compresser cope with HVLP type gun ?
![]() 902 Posts Member #: 111 Post Whore Loughborough |
17th Apr, 2007 at 10:59:16am
HVLP gun won't be cheap, what compressor have you got? do you know the CFM output. If any one needs spares for a devilbiss guns drop me a message, i work for a disstributor for them and have all the tech documents on the guns.
![]() 162 Posts Member #: 1252 Advanced Member Cornwall |
17th Apr, 2007 at 12:04:08pm
On 17th of Apr, 2007 at 12:28am RogerM said:
Steve, I have a JGA that is donkeys years old, still use it for regular primer. JGA and GTi are very similar, it's just the air cap technology that moved on for the GTi, basically the GTi is just a HVLP JGA. Should have mentioned that a good friend of mine regularly paints VW campers with a Clarke gun and swears buy it ..... he does look after it and has a fair idea of how to swing it..... It's like many things .... you get what you pay for up to a certain level then after that it's mainly just paying for a name. My George jeans I'm wearing right now cover my fat ass just as well as a pair of Levis but they won't last as long (not that it matters much if I paint a car wearing them ... which I probably will ..) ![]() My cheap jeans always seem to outlast my expensive ones! |
17th Apr, 2007 at 12:30:18pm
On 17th of Apr, 2007 at 12:09am RogerM said:
Aim for something like a 1.4mm nozzle on a HVLP or a 1.8 on a standard gun and you can't go too far wrong. I've been recommended to go for slightly smaller nozzles, I've currently go a 1.8 in my JGA and whilst it was fine for primer I found it a bit big for paint and lacquer, and I’m considering going for a 1.6 in the future. On 17th of Apr, 2007 at 12:09am RogerM said:
The debate on suction and gravity will rage forever and it all depends how you work. I have both type and use them differently for different jobs. Gravity fed is easier to work with for most of the car but there are angles you just dare not put them at as none are truely leak free and the paint still needs to flow downwards to some degree ...... hence why I use a suction gun for priming as you can swing it around with total abandon without fear of interupting the flow or dripping. I found my suction gun quite wasteful; when I sprayed the MG I had to do it as individual panels due to the size of my spray booth (gazebo) after each panel I was left with about 50ml of paint in the bottom of the gun, that I had to through away, now this doesn’t sound like a lot, but when you think about the number of panels on a car & times that by the numbers of coats of paint (primer, base & clear) it adds up to a lot of paint going into the slops bucket. On 17th of Apr, 2007 at 10:59am Alex1340 said:
HVLP gun won't be cheap, what compressor have you got? do you know the CFM output. If any one needs spares for a devilbiss guns drop me a message, i work for a disstributor for them and have all the tech documents on the guns. Alex, I may have to take you up on that offer :) Isambard Kingdom Brunel said:
17th Apr, 2007 at 01:31:26pm
i think it is 8cfm, it is steves old one, here is the link. it has adjustable reg on it, and seems pretty cool, as a test i charged the tank then left my spray gun on constant to see how long it would take to drain, it took effing ages :)!!!! i searched for the JGA guns but they are all suction jobbies.
17th Apr, 2007 at 06:21:38pm
NOTE ON THE AIR FED MASK!!!!!!!
17th Apr, 2007 at 08:52:17pm
I'll find out tomorrow for you. I'll dig out my price list and let you know PM me you email address or just drop me a line at alex.heap@airchannel.co.uk |
