Home > Help Needed / General Tech Chat > Locking Wheel Nut Removal
pickmeup
Member #: 1200
Im trying to get a locking nut of one of the wheels so i can do the brakes, does anyone have the socket to fit this type of nut?
If so can i borrow it!! Cheers , Gaz
Kean
Member #: 341
aka T2clubby
South Staffs
If it is steel, just weld a suitable nut on to it.
if its a decent locking nut, each key/socket should be slightly different anyway, so its unlikely that anyone will have a suitable key.
usa a blunt chizle and knock it round
if you have no welder
looks like thats whats been done before!!!
pickmeup
Member #: 1200
yeah i have a few options, there is some thread left in the nut so im thinking of welding a bolt on and tryiong that .
Other option is the old socket trick hammered on , im not keeping the nut but its always easier if you have the right tool *tongue*
...said the bishop to the something or other...LOL
adam1330
Member #: 238
essex
i had this problem a few months back, i used the socket hammered on trick..! worked a treat.
Dangerous
Member #: 417
I've drilled that sort out before
a squirt from a welder really helps as it loosens stuff up*smiley*
pickmeup
Member #: 1200
will bash the feck out of it tomorrow and let you know how i get on!
evolotion
Member #: 83
Glasgow, Scotland
a set of these will get it off no bother :) neven if you dont need them for wheel nuts buy a set anyways (there is anotehr set on the site to make a complete set, the ones i linked to are jstu a few extras you can get) they are worth there weight in gold
http://www.machinemart.co.uk/shop/product/...ets/brand/irwin
Edited by evolotion on 17th Apr, 2007.
Denis O'Brien.
pickmeup
Member #: 1200
got it off thanks to the welder and a pair of mole grips!! *tongue*
