Home > Help Needed / General Tech Chat > harmonic balance
clubby_turbo
Member #: 403
sydney Australia
Hey all, im thinking about buying this harmonic balance/pully set up for my 998 turbo engine, i was just wondering if anyone can see it being a problem when i go to mount a trigger wheel on it for megajolt?
http://www.minispares.com/Product.aspx?pid=33621
Thanks. Chris
998 turbo
Depends what trigger wheel you are using.
The last thing you would want to do is have 160 squids worth of wheel turned down to fit a Ford ring.
I suspect that this
http://www.kad-uk.com/crank-sensor.htm
would go straight on, but it's not the cheap option.
clubby_turbo
Member #: 403
sydney Australia
thanks for that, yea well i plan on making the trigger wheel myself, it's not a cheap set up but i think it'll b worth it in the end.
Thanks again. Chris
998 turbo
