Home > Help Needed / General Tech Chat > Hoses for dump valve??
hammoj28turbo
Member #: 1502
Aberdeenshire, scotland.
Can anyone tell me what size and length of hosing do i need to fit a dump valve? Length and breadth? Also the small hose that comes off the top and goes to the inlet manifold?
Also wheres the best place to buy them?
Many thanks
James.
a small piece of 1" for the main bit
and some 5 or 6mm for the vacuum bit.
i used 4" of the 1" dia stuff at most and maybe 12" of the 5/6mm stuff.
it depends a bit on your setup.
Some suit a 90 degree bend in the 1" hose to help clear the bonnet but i;ve always put my DV takeoff's in horizontal, bit more work but looks a lot neater.
hammoj28turbo
Member #: 1502
Cheers mate, thats spot on. Perfect. :) Yeah, i too prefer the dump valve horizontal and not with a bend in the pipe.
Edited by hammoj28turbo on 18th Apr, 2007.
hammoj28turbo
Member #: 1502
You reckon that 2.5" long would be ok for the dump valve? Just that i can get a bit designed for dump valves for £4.lol.
well the metal of my DV and Plenum are touching near enough so it only needs to be long enough to seal on each.
i would of thought 2.5" would be fine.
hammoj28turbo
Member #: 1502
Cool, its just that its cheaper than buying a big bit. Thanks again.
Cheapest way is to use an old top rad hose. *wink*
hammoj28turbo
Member #: 1502
Hehe, there is that....but i like the blue hoses.lol.
They do silicone ones aswell...I had one so I used it 'cause I was tight. Lol.*wink*
double post. :$
Edited by matty on 19th Apr, 2007.
hammoj28turbo
Member #: 1502
Just ordered silicone one that was quite cheap. Yeah, iv seen the rad hoses in silicone. Gotta get some of them but they are kinda expensive.
