| Home > Help Needed / General Tech Chat > Bearing | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
19th Apr, 2007 at 09:01:11am
Any tip of knocking the bottom bearing race out of the crank case? (goes on the end of the shaft of the bottom drop gear) tool for job? |
19th Apr, 2007 at 09:09:23am
I assume you mean removing the first motion shaft bearing outer race from the transfer case.
19th Apr, 2007 at 05:15:27pm
I use this method. Got three different pullers for the A-series casings alone. Not cheap, but the proper tool.
19th Apr, 2007 at 06:36:45pm
this has been coverd before
19th Apr, 2007 at 10:13:35pm
thanks for that benross read hanyes it says do not apply direct heat but did say you could use boiling water but i thought this wouldn't be good enough! Read in that thread that people warm them so i might try a boil lamp! the way you did it was good but looked alot of work. just scared when might do damage to the bearing higher up and i dont want to change that |
20th Apr, 2007 at 01:50:23am
to be honest, i have no sucsess but......turbo daves method .......... ..gets results .......
20th Apr, 2007 at 10:43:59am
which is ?? |
20th Apr, 2007 at 12:43:59pm
search and ye shall find mate. Every day is a school day ...........
20th Apr, 2007 at 09:38:06pm
jobs good went round it with the welder so much easyer than all this other |
100 Posts Member #: 745 Advanced Member Northampton |
5th May, 2007 at 11:30:46pm
<smug> - i have the proper rover tool for pulling it: even easier! <smug> |
