Home > Help Needed / General Tech Chat > Building up diff with a LSD & semi hel cwp
probably a simple one this.
should this be done as per haynes, or is there anything that should be done differently?
cheers
joe
You need to set the preload/bearing shims on the opposite side to what the Haynes says when fitting the side plates on the diff casing.
thanks, glad i asked now.
