Home > Help Needed / General Tech Chat > sorry for all the questions today! steadies
mark4765
Member #: 249
whats the normal for a turbo mini regarding engine steadies...ive only got a top one which is uprated....will i need a bottom steadie and do they fit without drilling subframe??
regards mark
Adding the head steady from the thermostat housing to the bulkhead is a good idea. I have also added steadies from the speedo end of the gearbox and the flywheel housing, these go rearward and bolt to the subframe.
The more you can add the better really, the thermostat one being the most worthwhile.
Phil. *smiley*
Dicanio
Member #: 91
Phil, how have you attatched the thermostat one to the car, bearing in mind the crossmember where it normally bolts has been removed to get the turbo in..
jamesfawcett
Member #: 218
Bingley, West Yorkshire
people make custom brakcets, ive been trying to research them myself, i think turbodave uses one but i cant see clearly in the pics
I have a picture of the bracket i made so i could use this steady, but i don't know how to post it on here ?
Phil. *smiley*
Dicanio
Member #: 91
Phil, can you e-mail to me please at mark.dicanio-10@tesco.net Cheers
email me it mate and ill host and put up here *smiley*
iain@turbominis.co.uk
Will do this afternoon.
Phil. *smiley*
Mail sent guys.
Phil. *smiley*
Havent got anything mate, ill keep checking though then post it up here *smiley*
here is my old bracket
Bit neater than mine lol
Phil. *smiley*
PS. Let me know if you don't get it soon, & i'll send it again.
Edited by Turbo Phil on 28th May, 2004.
*smiley*
Cheers Matey !
Phil. *smiley*
no worries. Still got mine to weld in at some point or another!
speedster turbo
Member #: 244
When I installed my top mount, I had to cut it down to clear the turbo box, it used 1 of the standard LHD bolt holes, I just drilled 3 more, all of which are still accessible from underneath where the LHD pedal box goes. Would love to send pics but my engine bay is rather full, don't know if I could get the camera in to the area.
Speedster turbo under construction
speedster turbo
Member #: 244
By the way, I also have the mount on the flywheel end and a front mount going to the subframe on the flywheel end. Engine moves NOWHERE!
sauber 200
Member #: 245
competition shocks make great steadies.use them on my rally mini.
