Home > Help Needed / General Tech Chat > Exhuast wrap
Alex1340
Member #: 111
Loughborough
Why don't many people seem to use exhuastwrap on minis?
Seems like a really good idea to me and i am thinking next time i need the exhaust manifold off i'll wrap it up.
Nick
Member #: 154
Midlands
my turbo manifolds wrapped, glad i did it this time around, under bonnet temps are significantly lower now!
lots of people don't use it because of cracking problems, as far as i know this is only an issue with stainless though.
Turbo Shed
Member #: 30
Epsom, Surrey
i've wrapped mine for the past couple of years and i know need a new manifold. the standard cast iron metro turbo manifold has distorted to the point the stud holes are about 3 or 4mm out at each end!!
this distortion makes it a bitch to fit and the ports dont line up very well even after the use of a dremil
i cannot prove its due to the wrap but until wrapping i never had a problem. then again i've used the same manifold for about the last 12 to 14 years
Mines been wrapped for a few years now, no probs. My mate runs a stainless manifold wrapped, again no problems here.
Alex1340
Member #: 111
Loughborough
It just doesn't seem to be a comman thing on minis and will with the NA carb monted were it is it makes sense to wrap the manifold.
i'll get some exhuast wrap i think! colder intake for me, mawhaha!
Zeemax Power
Member #: 393
Oulton Park
I brought some of this not very the stuff i brought and no matter what i do cant find anything to hold it in place and how you wrap the turbo manifold god no any idea would be great
http://www.Zeemax.com
Zeemax Power
Member #: 393
Oulton Park
i find the metal zip ties you get rubbish cant get the to tighten enough whats others use cheers rob
Sir Yun
Member #: 1592
Smart Guy!
stainless hose clamp.
I have used it but if you can have a choice ( budget wise) i would probably get it coated
Edited by Sir Yun on 28th Apr, 2007.
Turbo Shed
Member #: 30
Epsom, Surrey
i just wrap it round on its self and dont use any clips. much neater than clips and stays tight.
Nick
Member #: 154
Midlands
i use thin lock wire on mine.
I'm thinking of taking mine off now though after seeing a few of the super mighty's LCB's folding in half due to the heat being kept in them.
shane
Member #: 1246
Lowestoft, Suffolk.
When I used it on my free flow manifold for my 998, I wrapped it on its self so i only needed to clamp it in one place, which was where it met th link pipe, I only used a stainless cable tie.
I now dont use it as layers of metal started to flake off the manifold!!
Shane.
