Home > Show Us Yours! > Turbo clubman
steve7786
Member #: 1628
Just bought this with my brother (squinty) for a new project car.
We already have a metro turbo engine, just need to sort a decent gear box and a few other bits out.
It should be finished off sometime this year hopefully.
Should be fun once it's completed
Here's a few pictures of the bits that we've put together so far, hopefully i'll get some good ones of the shell when i get it out of the garage.
Metro front mounted radiator and fan
Cylinder head ported to around 29cc on the combustion chambers & tapped for the heater matrix
Starmag 7x13 alloys, have two spares as two on the car are slightly buckled. Thinking of using them for slicks for 1/4 mile runs if they can be straightened out
Center console and gauges
Cosworth 2wd intercooler, actuator, pre-verto clutch slave cylinder, flywheel bolt & extended arm
Gaskets, braided master cylinder to slave cylinder hose & engine mounts
Lightened clutch back plate, AP rally plate, grey pressure plate & clutch release bearing
Spec-r breather tank
Ultra light flywheel with pre-engaged ring gear
Straight cut 1.1 drop gears
Central oil pick up pipe
Carbon fibre dash & clocks/gauges
I'll keep things updated as progress is made.
Ah yes i remember this rolling shell being on ebay, looks good so far!
Interesting head there. Nice seat too.
hammoj28turbo
Member #: 1502
Aberdeenshire, scotland.
Very very nice. Gonna be good when its finished.
johnK
Member #: 690
Norfolk
really nice - like the colour as well
JK
If Carling made Mini engines
like the colour, looks like a nice little project you have there, but i hate those obscene drace bars,get rid of em.
carl
Edited by fastcarl on 22nd Apr, 2007.
AL
Member #: 1347
Croydon (South London)
looks great so far.
clubman_dan
Member #: 142
Winchester
looks sweet, i like the carbon dash, and it looks like you have plenty of goodies to use in the build too.
nice one :)
squinty
Member #: 665
Birmingham
Thanks lads any info given would be helpful as its our first mini turbo *smiley*
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
I remember seeing this on ebay and had just got my student loan at the time i was so tepmted!! Nice car 8)
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Nice project. Liking the colour mate :)
On 19th Jan, 2010 wil_h said:
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Great pics.
Looks like its all ready to go together anyway.
Who did the head work?
giallofly
Member #: 164
The Stig..
Newport Pagnell
looks very good, just make sure you use the proper turbo exhaust/inlet gasket as the one in the pic will blow in no time at all..
JF
So that's what they look like. Who'd think....
Looks a nice project, however for your first assignment you need to move the fuel pump, the metro turbo pumps are not designed to lift fuel on their inlet side, and won't happily do so, the pump needs to be below the tank to get a gravity fed supply of fuel to its inlet.
squinty
Member #: 665
Birmingham
Hi Guys,
Haven't been around for a while anyways. The cylinder head was done by Ivor Searle and before anyone says there is no squish etc etc They followed the info I sent them. As a newbe I wasn't that clued up. But I'm after high boost on standard pistons so cheapest way I figured.
I had a feeling that the fuel pump needed to be gravity fed. It was like that when I brought it. There is space in the old battery box for me to put it there. Would this be a good idea? Would be free from water road salt and anything that might cause damage . The only down side I can think of is the noise if its in a small space could use dynomat stuff people use when doing sound installs.
The battery is going to be on the passenger side by where the back seat used to be for weight distribution Gel filled one in a sealed battery box.
Is there something wrong with my oil pick up pipe? Just wanted to post everything I had got a few more goodies such as heat wrapped inlet and exhaust manifold along with carb heat shield to stop heat transfer want those charge temps as low as I can get them. Also got myself a water injection tank thinking 50 50 mix water alcohol.
Don't think this is common to do on the a series but thought Id give it a go help lower the charge temps some more plus added octane and keeps valves pistons and chambers clean as the steam produced in combustion steam cleans it and the A series is known to coke up causing det and engines to run on once switched off.
