| Home > Beginners Tech > 8.4" brakes | |||||||
56 Posts Member #: 1614 Advanced Member Chard Zummerset |
24th Apr, 2007 at 07:55:31pm
Howdoo
when i drove a 10" wheeled Mini last it felt insane ! |
9th May, 2007 at 06:14:32pm
The 8.4 4 pot caliper is only for 12inch wheels, you need 7.5 4 pot calipers and cooper disc setup for tens 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
9th May, 2007 at 08:33:39pm
dont think 6 pots fit under 10's.
Edited by iain on 9th May, 2007. |
9th May, 2007 at 08:39:48pm
minisport 6 pot caliper??
10th May, 2007 at 08:18:19am
standard 4 pots and 8.4" vented disks can be made to fit under 10" wheels! turn the disc down to 7.7" and move the caliper in and remount. i have done it and it does work. what you cant do is fit standard 2pot calipers. you can even use the solid disc as long as you use the 4pot caliper with out the spacer in the middle
11th May, 2007 at 07:37:55pm
thanks guys, all this info has been helpful.
11th May, 2007 at 10:20:04pm
On 11th of May, 2007 at 07:37pm Paul6266 said:
thanks guys, all this info has been helpful. Due to the cost of the calipers i may do the fiesta brake conversion You might as well run drum brakes on the front. Paul I seriously doubt it! |
11th May, 2007 at 10:27:43pm
thanks guys, all this info has been helpful. Due to the cost of the calipers i may do the fiesta brake conversion You might as well run drum brakes on the front. Paul Sorry Paul, but I'm going to have to disagree with you there, I've got Fiesta brakes on my Mini and they are more than up to the job in my opinion. Isambard Kingdom Brunel said:
524 Posts Member #: 1380 Post Whore Swindon |
12th May, 2007 at 12:10:07am
as i'm planning on running the fiesta caliper set up on the front, can anyone confirm what sort of braking power they give?
neil_g, with all due respect, your the worse salesman on TM since rob_h tried to sell his own ass |
125 Posts Member #: 751 Advanced Member Aberdeen |
12th May, 2007 at 07:50:31am
I have mini sport alloy 4 pots using 7.5 discs and my 10inch GB alloys fit over them but standard 10 inch steel rims catch on the calipers which i found when i tried to move my mini which resulted in me scouring the edges of my new gold calipers!!
12th May, 2007 at 09:13:00pm
On 12th of May, 2007 at 12:10am Ollie said:
as i'm planning on running the fiesta caliper set up on the front, can anyone confirm what sort of braking power they give? as seems there are mixed opinions (sorry for the thred hijack) I can't tell the difference between my old 8.4" brakes & my fiesta conversion. I'm sure others will offer differing opinions. Isambard Kingdom Brunel said:
16th May, 2007 at 07:22:25am
If you work out the ratio of piston sizes and the pad areas you should find that if anything the fiesta conversion gives you more than a 7.5" S set-up and nearly that of the 8.4.
