| Home > Help Needed / General Tech Chat > DASHPOT OIL | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
25th Apr, 2007 at 05:31:44pm
Did a search but cant find anything on this...
Shit Happen's |
25th Apr, 2007 at 05:46:14pm
That's what i use, i've found the best results using it. I know some people use really thick stuff like 20/50, but mine was terrible using that. |
25th Apr, 2007 at 05:49:31pm
Think ill try that then :) Shit Happen's |
56 Posts Member #: 1614 Advanced Member Chard Zummerset |
25th Apr, 2007 at 07:21:59pm
Yep i always use 3 in 1 as its alot thinner works a bit better in the dashpot. should run it dry if its mot time though cus it puts up the co level a bit more than it should when i drove a 10" wheeled Mini last it felt insane ! |
25th Apr, 2007 at 08:24:15pm
I'm using dot 4 brake fluid !
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
25th Apr, 2007 at 11:28:29pm
I use the su oil from minispares.
26th Apr, 2007 at 01:58:03am
"Apparently" trolley jack oil is the stuff for dashpots so ive heard! |
26th Apr, 2007 at 06:54:05am
i have always used gearoil sea80-90. gives better constiant rise rate when hot.
26th Apr, 2007 at 07:32:18am
I use Eggnog.
28th Apr, 2007 at 06:48:22am
I use autotrans oil , same fluidity as su oil, but easier to find |
455 Posts Member #: 1502 Senior Member Aberdeenshire, scotland. |
28th Apr, 2007 at 12:06:41pm
Iv always used 3 in 1 but looking at the above i may use thicker for the turbo.
28th Apr, 2007 at 12:26:44pm
2 dashpot springs or a heavy duty one helps stop it rising to quick too
44 Posts Member #: 1645 Member Adelaide Australia. |
29th Apr, 2007 at 06:39:26am
Due to the temp, espeically in summer here everyone uses ATF. But I have found this to be a bit thin, plant yor foot down it hesitates a bit and A/F ratio guage show lean (piston lifting too quick) |
29th Apr, 2007 at 09:34:13am
a stronger spring with blocked "part throttle leaning pipe" should correct this lean situation that cannot always be by the oil grade alone. |
