| Home > Help Needed / General Tech Chat > Whos running perspex Windows?? | |||||||
25th Apr, 2007 at 09:19:25pm
? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
25th Apr, 2007 at 09:24:50pm
not perspex but polycarbonate on all except the windscreen. |
25th Apr, 2007 at 09:26:40pm
will be running 4mm polycarbonate...roughly £90 for 2x1 sheet. As Mark says...just side & rear windows On 19th Jan, 2010 wil_h said:
25th Apr, 2007 at 09:30:16pm
What are they like for road use (do they rattle??) 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
25th Apr, 2007 at 09:46:55pm
don’t know.. not used the car since the rebuild |
1425 Posts Member #: 690 Post Whore Norfolk |
25th Apr, 2007 at 09:58:56pm
the only rattle you get is from the sliders in the front windows - not too bad in reality - the others are all fixed.
If Carling made Mini engines
25th Apr, 2007 at 10:24:06pm
im using them in a std style
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
25th Apr, 2007 at 11:26:54pm
Planning to you macrolon,
25th Apr, 2007 at 11:39:05pm
pardon? |
25th Apr, 2007 at 11:47:35pm
you can get antiscratch coatings now, my windows have been going up and down for 2 years without a scratch |
831 Posts Member #: 908 Post Whore gateshead |
26th Apr, 2007 at 12:43:40pm
i have fixed poly fronts. no rattles. me and my mate did a destruction test on some to see if it possible to beak it. couldnt even get it to dent with a hammer!!!!!!!!!!!!!! just dont do the lot as you may need a means of escape in an emergenct sometime! balls to the blower!!!
26th Apr, 2007 at 07:28:47pm
Thats what I'll be using. I think it has anti UV properties. So won't go shit with sunlight. :)
26th Apr, 2007 at 07:34:42pm
old sunbeds are a good source for uv resistant poly, found one down the tip, so thats what i replacing the windows in my boat with. "Turbo's make torque, and torque makes fun"
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
26th Apr, 2007 at 07:40:54pm
On 26th of Apr, 2007 at 07:34pm joeybaby83 said:
old sunbeds are a good source for uv resistant poly, found one down the tip, so thats what i replacing the windows in my boat with. Now thats a top tip. think of all the naked skanks that have been all over your windows tho
26th Apr, 2007 at 07:43:21pm
Yep..good top tip indeed. Just one srape of all that dead skin....and they're ready to go!!!!!!!! lol On 19th Jan, 2010 wil_h said:
27th Apr, 2007 at 08:51:02am
goldmember '' oohhhh ,thats a keeper"" Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
27th Apr, 2007 at 11:06:51am
yep ,and beyonce deff falls into the bct(big christmas turkey..(needs a lot of stuffing )) bracket . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
