Home > Wanted > loads of bits for my 998 turbo project needed
8ballmini
Member #: 1685
rochester kent
Exhaust manifold (Metro, Mirage or other)
Inlet manifold
Turbo Carb
Plenum
Intercooler (optional)
Hige pressure fuel pump
Fuel pressure regulator
Fuel return Pipe
Turbo oil feed
lightened flywheel
turbo clutch plate
t2 turbo
+20 rebore or +40 not 100% sure what it needs yet
pistons
turbo cam
duplex chain
new cam followers
double valve springs
am new to this site and havent received an activation email so incase the PM system doesnt work can you email me at jonnyburno@hotmail.com
Welcome, just been reading your post on minifinity. LOl
Not sure whats still up for sale, but this link may help with some parts.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=149744
If the budget will allow I would recommend buying the following new just for peice of mind.
Fuel Pump
Return fuel line (cheap so may aswell get new)
Turbo oil feed ( Not worth risking buying a used one)
Clutch plate ( Not expensive new)
Edited by matty on 26th Apr, 2007.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Do a search on here..it will find most parts you need, or people to make them! *wink*
