Home > Help Needed / General Tech Chat > the ECU of metro turbo
gapi
Member #: 286
scuse for my english i'm french.
I make a mini turbo , but i have a probleme.
do you conserve the ecu of metro turbo? for make the pressure regulation or do you make a classique config as super5 gtt ?
thinks
www.saxo-vts.com
You can run without the ECU as most people do. The ECU on the Metro Turbo is used purely to limit boost below 4,500rpm.
Giving 4.5psi below this & 7psi above. Running with out it will give you a constant 4.5psi, as this is what the actuator is set at.
Phil. *smiley*
