Home > Show Us Yours! > WANTED: Pictures of fuel pump locations and installs
chinlesswonder
Member #: 1192
In the garage......again!!
All welcom, just need a few pointers as to where to fit the fuel pump and pipe in.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
Turbo Tel
Member #: 588
Delaware, USA
This is only really good for a DTM exhaust but heres mine, the blue thing is the pump and the silver a fuel filter with 2 inlets one from the tank and the other the return fuel from the regulator. The loop you see is the outlet of the filter looped to the inlet of the pump, This has the same effect as using a "T" instead of a return to the tank that others seem to have used succesfully, I thought I would try it first.
I bolted a metal strap to the subframe and mounted the pump on it using rubber reels, the filter directly.
Mini_Andy
Member #: 432
mine is in the spare wheel section, but sorry no pics
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Does anybody use an inertia switch incase they have a bump? I know our old escort had one and I'm sure they're cheap so might try one.
On 7th Nov, 2008 Nic said:
naeJ
m
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Jay .... really cheap from a breakers!
Don't run an electric pump without one .... it might be the last thing you ever do
chinlesswonder
Member #: 1192
That looks a good setup turbo tel, anyone for any more?, boot mounted installs perhaps? all ideas welcome so keep em coming
keith
Im going to be using the exact same setup for this one!
benjamin
Member #: 621
nsw austalia
heres mine probly not what your after tho,
its a holley blue fuel pump cabable of 14psi with no return line will be changing to an ijection style pump and return line soon as this setup only alows me 10psi boost
oh and the pump is really noisy even rubber mounted
1152cc turboed mini clubman, most powerful 1.1L a-series?
http://boostmini.justboard.net/
the metty pumps prefer a gravity feed. Mines just mounted to the boot floor, at the minute via some big cable ties!!
chinlesswonder
Member #: 1192
Turbo Tel, what is that fuel filter off, never seen one with two outlets before.
A better pic here. I really love the Anodised Fittings!
