| Home > For Sale > Carb heat shields | |||||||
1st May, 2007 at 07:13:34pm
Finally got heat shields sorted. Made from 1.2mm stainless steel. They are natural not polished or grained finish. They bolt on to the plenum & carb/manifold.
Edited by Jason G on 19th May, 2007. On 19th Jan, 2010 wil_h said:
1st May, 2007 at 07:18:11pm
1st May, 2007 at 07:20:41pm
cheers mini13. Had a bulkhead heat shield on my metro, gets damned hot! On another post nogin said about stainless....which in all honesty, I never thought of and I hold my hands up...sort of dismissed the idea at first. Edited by Jason G on 1st May, 2007. On 19th Jan, 2010 wil_h said:
1st May, 2007 at 07:27:36pm
Why doesn't it look like the original - ie two big holes instead of two small rectangular cut-outs?
1st May, 2007 at 07:31:27pm
Must admit...never seen an original one :(
1st May, 2007 at 07:36:17pm
Yep a bit less heat conductivety with old stainless IIRC
1st May, 2007 at 07:42:57pm
1st May, 2007 at 07:48:33pm
Ah - so this mounts to the bottom of the carb - using the two studs in the intake?
1st May, 2007 at 07:52:07pm
Yep it locates on the 2 lower carb>manifold bolts. Just seemed obvious place to put them for extra support. Left enough room to get a spanner in, hence the low sides. Edited by Jason G on 1st May, 2007. On 19th Jan, 2010 wil_h said:
1st May, 2007 at 09:50:55pm
is there pics of one fitted yet mate??
My build thread..
1st May, 2007 at 10:15:19pm
Yep, it goes on plenum.....heres an early pic of my early model..
1st May, 2007 at 10:27:45pm
i see looks good mate.
My build thread..
2nd May, 2007 at 08:00:36am
