Home > Help Needed / General Tech Chat > Isky springs.
mikes minis
Member #: 421
nr newark lincolnshire
Can you fit isky springs with std top caps? also who sells isky springs in the uk. cheers
MIKE.
Anton
Member #: 764
Staffordshire
morspeed suppiled mine.. no idea on the top caps they came with the head i brought from him
turbochargedstu
Member #: 908
gateshead
morspeed got mine. think he uses std top caps. i bought some titanium ones and he told me off and made me sell them!!!!!
balls to the blower!!!
Now them ,its very important to make sure you are acctually getting genuine iskederian springs and not the crap pattern one sold by some of the well known cam grinders, , as far as i would go ,if you dont get the isky box they came in stay away, but then again if you do get the box all's well,
i know about these pattern coppies through my own indevours to get a fitted length that would allow my mega high lift exhaust nitrous cam to work,
the kent cams pattern iskys [copies] would not allow what i needed, so a call to Paul Ivey, at specialised Valves had me sorted,
he also had a tale or two to tell about the inferior types,
make sure they are genuine !!!!!!!!,
also , isky spring are slightly smaller on the coil ID by about 0.5mm so if you use standard caps you need to expand them onto the caps.
carl
Edited by fastcarl on 2nd May, 2007.
turbochargedstu
Member #: 908
gateshead
hmmm thats interesting to know carl. i will have to have a look at mine next timei gave the rockers off!
