Home > For Sale > Mini Turbo for sale!
Roadrocket
Member #: 1425
Yorkshire Wolds
Heres the spec:
Body
1982 Mini Mk4 shell with removable steel front end (one piece - not flip front)
Webasto Sunroof
Vinyl roof.
Group 5 arches with chrome strip
MK2 rear lights and chrome around door surrounds, with cooper S badges and grille.
Wipac Halogen Headlights
Twin tone Airhorns.
Turbo box installed into bulkhead
Battery Isolator fitted.
Wheels 100+ 10inch minilites 5x10 with falken tyres.
MK2 Cooper 100MPH Speedo, Original 60s Smiths Rev counter.
MK2 Black vinyl front seats, Black Vinyl interior with chrome door handles etc.
Electric Aux Fan for those traffic Jams
Wooden Steering Wheel
RC40 Twin box Exhaust
Brakes:
Later rover pedal box servo controlling 4 pot Mini spares alloy calipers, on original Cooper S hubs and 7.5 inch discs. Cooper S drums on the rear, with S sized brake cylinders. Steel braided brake hoses fitted to front.
Suspension Front highlos fitted with kayaba shockers. Rear suspension standard.
Engine: Original 1275 MG Metro Turbo engine, with std pistons and rods, recently undergone bottom end recondition including new oil pump
MG Metro camshaft fitted (better performer than std turbo cam)
Minispares MS3 Stage 3 road rocket cylinder head Unleaded, with bronze guides and race valves,gas flowed and ported, with lowered chamber size to 29.5CC
T3 Turbocharger with braided steel oil feed
Bailey dump valve
RS Turbo Intercooler and pipework (removed from car)
STD Metro Electronic turbo dizzy.
Turbo Oil Cooler
Minispares 2 Core V Radiator does the job well.
Green High Flow air filter
Adjustable boost bleed valve with boost gauge
Oil Pressure excellent at all rpms.
Fuel delivered via MPi injection tank and pump
STD Later cooper sportspack gearbox with 2.7 final drive.
110BHP at the wheels at 10psi boost rolling road tuned so fuelling now bob on. Carb recently been overhauled and new float needle fitted.
Mini Comes with CB radio and mag mount aerial too and other stuff! A must for all mini adventures.
A great little car thats needs a little TLC on the body, the body is solid underneath with new sills recently fitted, but slight rust appearing on the rear end and door bottoms, a new speedo cable needs fitting. Both subframes in sound condition.
With high gearbox ratio, this motor will eat the miles on the Motorway, cruising at 80+ if req.
Tow Bar fitted.
Will sell with 12months MOT
If your interested in this please either ring me on 07884373620 or email leithdean@hotmail.com for more information or to make me an offer. Not placing this add on ebay just yet, and dont intend to break up for spares, but its upto you what you want to do with it.
Offers in the region of £1850 bargain! Will throw some other spares in, I have loads of spares to go too, need the space
Pictures taken 2nd May 2007. Intercooler has been removed. All thats needed to fit it is a modified plenum chamber and some short lengths of silicone hose.
Cheers!
stefaz
Member #: 1656
stoke-on-trent
What spares you got going please mate? Wish I could stretch the budget for the car tho.
Ant
this gents is worth every penny
i know this man
Roadrocket
Member #: 1425
Yorkshire Wolds
Thanks Benross very nice!
I have a STD Turbo head complete straight off the engine in running order could do with decoke and new valve seals, a couple of hours work all in all, open to offers.
I have two A+ blocks one 1275 STD and one 1293. Cam bearings are good both.
I have two gearboxes from later MG Metros I believe one has a 3.1 and 3.4 final drives. Also have transfer cases (A+)
Also theres an Mg Metro head in STD condition same as above.
Got a borg beck clutch (Preverto) complete with flywheel, backplate, diaphram, and clutch cover, all you need to convert.
Plus boxes of nuts bolts etc!
Open to offers for above, but must start to get rid
Roadrocket
Member #: 1425
Yorkshire Wolds
Mini Now sold, Admin pls can you remove post?
cheers
Deano
