Home > Help Needed / General Tech Chat > rocker clearances
Alex1340
Member #: 111
Loughborough
Hi guys,
Advice on the clearance for setting the tappets. minisport told me to set them to 0.017 and well makes a racket. will try re-adjusting but advice please.
Thanks
Alex.
as a guide if its a standard cam 0.012 inlets
0.014 exhausts this clearence will take into consideration wear in the valve train and give you a margin of saftey
Alex1340
Member #: 111
Loughborough
Should of stated that there roller tip 1.5.1 rockers and a kent 286 cam.
Thank you.
