| Home > Help Needed / General Tech Chat > rod/piston removal | |||||||
![]() 1128 Posts Member #: 142 Post Whore Winchester |
28th May, 2004 at 02:21:56pm
i am aware that you need a ring compressor to put pistons into a block but to remove the rod and pistons can you just pull them out the botom of the bore or is it a bit more technical than that? |
28th May, 2004 at 02:46:03pm
You cant pull them out the bottom, you need to push them out the top.
28th May, 2004 at 02:48:31pm
unless you have the block inverted, then you pull them out the bottom On 15th May, 2009 TurboDave said:
28th May, 2004 at 02:50:32pm
No you can't, the pistons need to be removed out the top of the bores. They will not come out the bottom believe me ... |
28th May, 2004 at 02:52:23pm
phil, if the block is inverted, then the top becomes the bottom, and the bottom becomes the top, so you can. Also if you put the block on it's side, you can them reomved the pistons from left to right action. LOL On 15th May, 2009 TurboDave said:
28th May, 2004 at 02:57:19pm
Oh the comedy ..... lol |
28th May, 2004 at 08:00:38pm
just got back from the garage.
