Home > Help Needed / General Tech Chat > what do i set it too ?
Mark1275GT
Member #: 886
London.
How do i tell what cam i have, i know its been changed from chain to belt drive. as i really not sure what to set my valves at. in mm.
What you think, done a search but there's all different setups.
Just want to know what i would set my too ? :)
nogin
Member #: 487
westbury, wiltshire
cam should have numbers stamped on it thats the only way you are going to know what cam it is and that means taking bits off to see
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Could always clok off the top of the push rods and measure lift and duration and look at the tables most cam manufactures have on their websites.
Mark1275GT
Member #: 886
London.
Right then,
I emailed the guy who used to own it, and he said it's a Piper turbo cam ?
turbo hogster
Member #: 178
stowmaket suffolk
safe bet is 15-16 thou depending on your rockers you are using, but you wont go far wrong with those figs.
Mark1275GT
Member #: 886
London.
So what would that be,
inlet (0.35mm)
exhaust (0.40mm) ?
Not sure what rockers i have.
How would i tell, would i need to find out, or would them settings be ok :)
turbo hogster
Member #: 178
stowmaket suffolk
well 40 thou is 1mm ish so sounds about right, 15-16 thou for both mate would be fine untill you can see what cam and rokers you have.
Mark1275GT
Member #: 886
London.
It's a Piper turbo cam.
What do i look for to tell what rockers i have. once i find what rockers i have, what do i do to find out what the correct settings should be. i checked the valve clearance, and there were on 0 :( that not good i take it. wouldn't of done any damage would it ? thanks for your help :)
Mark1275GT
Member #: 886
London.
Anyone know how i find what rockers i have then, to set it all right :) thanks
Post a picture.
Mark1275GT
Member #: 886
London.
Found out there standard rockers.
So i guess 15-16 would be too much right ?
Jay#2
Member #: 648
Northern Ireland (ex AUS)
What does piper have to say about valve clearances?
On 7th Nov, 2008 Nic said:
naeJ
m
Jay#2
Member #: 648
Piper say .012 (.30mm) for both in and ex for the mild road/turbo cam apprently.
http://www.pipercams.co.uk/NewPiperWeb/red...rover_a_cam.pdf
naeJ
m
Mark1275GT
Member #: 886
London.
Thanks for that jay nice one :)
