Home > General Chat > Get me new head.
Got me head from VMax, should be fitting it tomorrow so i'll keep you all posted. And once on the rollers i'll let you know how it goes.
Are you going to see Ray?
much different to the old one matt?
turbo hogster
Member #: 178
stowmaket suffolk
does a bear shit in the woods lizard.lol.
im sure he is booked in allreadey.
hope to see that running in a couple of days boy
Matt, Do you mind if I come along to see it in action?
Well looking at it the chamber is a little different shape, evey thing else seems the same, but its hard just looking at it. The RR will tell use if it's different.
Not sure when i'm going to rays yet.
I take it you all run hardened valve seats with todays heads ?
I actually found my old cracked Avonbar head from many many years ago buried under some crap in my garage a couple of days ago !!!!
Good luck with the new head...be interesting to see how it performs.
yes Stevie it has hardened seats, was thinking of going with out to help it stop cracking, but was advised strongly against.
i also run hardened seats with a 31mm valve stevie.
matt ,what happened ,was it all good ?
whats the valv sizes matt
whats happening, well LOL.............
F_CKEN thing! i pushed it a little last year, well a lot really, now every things going to pot on her! as you all no about the box prob, sorted that out, then the head prob, got another one made, now the bloody thing is miss firing!!...so to answer the questions and this is why i haven't posted, i did a RR with the new head but had problems with the mixture and it mix firing, so got to sort out the miss first. But the way things are going the summer will be over with before its sorted!
Ben i've just gone for 29 ex and 35.6 in on this head.
This was the very reason for not letting people know about the RR, as you can never tell whats going to happen.
Edited by Miniwilliams on 25th May, 2007.
do a compression check HOT mat
my guess is that the valves may be sticking in the guides when hot
if they are manganise bronze ones
they may need the reamer up them again
just a thougth
you'll find it matt and itll all be worth it
Interesting to say the least...
turbo hogster
Member #: 178
stowmaket suffolk
i still recon on coil pack mat
yep i would think of coil pack too matt , i had a sit on the rr where it went at 6500 onto 2 cyl ,and thought it was springs but now think it was coil pack ,good luck with it .
Good luck Matt, I hope to see your car run this year!
giallofly
Member #: 164
The Stig..
Newport Pagnell
New head and misfire is often valve guides.
May need an extra ream.
JF.
youm meen hone ,!!!
Cheers chaps, i see what your saying about the miss fire but it's not the head i'm very sure, as when it miss the shift lights flicker.
Nick
Member #: 154
Midlands
my shift light used to flicker when it misfired. turned out my car was leaning off quite bad as it came on boost. no idea why it made the shift light flash though. doubt its the same as your problem but worth a look :)
hell mate how weird is that! cheers for letting me know.
Nick
Member #: 154
Midlands
no probs...i only realised when i fitted a wideband lambda and i saw the mixture drop as it did it.
i was convinced it was an electrical fault before that cos the shift light flickering was making me think the coil pack was breaking down.
Funny you should say that Bud....mine does exactly the same (shift lights all flicker together and jolts). I thought it was some wiring problem, something earthing out maybe?
How did you sort yours in the end Nick?
Mine does it on low revs when you go to accelerate, its worse when its either really cold or really hot!
