Home > Help Needed / General Tech Chat > turbo
wakkkky
Member #: 1705
i have a 1982 998 mini at the moment and currently looking at converting it to a 1293 turbo from morspeed and i wondered what extra parts i need to be able to put this engine in ill leave the link for the engine thnx all
http://www.morspeed.co.uk/minienginescompl...urbobooster.htm
Kean
Member #: 341
aka T2clubby
South Staffs
Search button
wakkkky
Member #: 1705
well i dont understand alot so i was just looking for some help
Take a look in the FAQ section.
Also - do NOT ask the same question in two different sections. Your duplicate has been deleted.
www.turbo-mini.com has a lot of good info nicely laid out for a beginner like yourself. I suggest you take a look there, and understand the basics. We will be able to assist you more once you understand what we are suggeating. :)
wakkkky
Member #: 1705
thank you i will i didnt relise you had a faq section
shane
Member #: 1246
Lowestoft, Suffolk.
From memery there is a deailed thread on what you need for a turbo install and how to fit it, as suggested, seach, all the answers are at your finger tips!
Shane.
wakkkky
Member #: 1705
what do search shaneyboy
wakkkky
Member #: 1705
i have since looked in the faq section and there is nothing that exactly suits what i am lookin for
shane
Member #: 1246
Lowestoft, Suffolk.
That is not an easy one to answer, as many people title thier threads in different ways, eg turboing a 1275, or fitting a t3 to a n mg engine, the topic can be the same but the title so very different! your best bet is to search thru using key words your would expect to see in the title, it will take a little thought and patientce but its all there somewhere, I sorry I cant pull a link out quickly for you.
If you do get totally stuck, you can always ring and chat to the chaps that are building your engine, Im sure they also will only be too happy to help you.
best of luck
Shane.
Mark1275GT
Member #: 886
London.
This might help :)
http://www.turbo-mini.com/4598.html
wakkkky
Member #: 1705
thanks shane
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I think I tried to answer this in your post in another section.
On 7th Nov, 2008 Nic said:
naeJ
m
