Home > General Chat > starter motor question
dan
Member #: 93
at the risk of sounding stupid, is the pre-engaged starter motor only suitable for use with verto/valeo clutch?
or can you use either?
just been reading the bill sollis book about preparing your mini for racing etc, and he mentions its best to pre-engaged starter so you can remove the end of the transfer casing cover for a bit more room. But he also mentions using non-verto clutch???
I am sure someone can answer this one pretty quick
Cheers!
You can change the ring gears if i remember correctly. Just get the correct ring gear for the starter.
Remember that pre-engaged are a fair bit more expensive and have the piggy back solenoid which gets in the way.
clubman_dan
Member #: 142
Winchester
non verto clutches have the flywheel as a separate part of the assembly this means that the flywheel can be made lighter on a pre verto clutch. which i guess is good for racing.
i use an inertia starter, i replaced it a couple of months ago and it cost ?25 i think pre engaged cost about ?80 if they need replacing
Edited by clubman_dan on 28th May, 2004.
dan
Member #: 93
fair enough just thought i'd ask, i think i'll be keeping the inertia starter, just asked because i'm starting to build up a collection of starter motors of both types!!
1310turbo
Member #: 41
i run pre verto clutch gear with a pre-engaged starter. on my lightened flywheel i had the ring gear put on for the pre-engaged starter as that was that the only one i had
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
dan
Member #: 93
interesting, not sure what sort of flywheel i'll end up getting when it comes to it.
cheers!
