| Home > Help Needed / General Tech Chat > fuel lines | |||||||
117 Posts Member #: 144 Advanced Member |
29th May, 2004 at 02:41:59pm
i have got some metal 8mm fuel pipe, do i use this for the return only or return and feed? |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
29th May, 2004 at 03:08:36pm
alright steve, this fuel line subject has been thrown up a few times on this forum so you should be able to find something if you do a search, as is the case for wiring up the fuel pump, some people use the standard metro turbo set up with oil cut out switch and timer relay, others use an inertia cut out switch in conjunction with the oil cut out via the relay, do some searching on the forum anyway
Edited by dan on 29th May, 2004. |
![]() 1014 Posts Member #: 238 Post Whore essex |
29th May, 2004 at 08:23:34pm
i'm using 8mm for the feed and return,had no problems with it. oh yeah, i'm using copper pipe run inside the car. Edited by adam1330 on 30th May, 2004. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
30th May, 2004 at 10:49:50am
ive used full rubber pipes. The bit i cant work out is the tank to the pump, i have connected it with 8mm hose but im now thinking this is wrong and maybe it should have been 10mm? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
