Home > Help Needed / General Tech Chat > Two questions, torque setting and paint quantity
Richspec
Member #: 300
Cumbria
Whats the torque figure for the main subframe tower bolts (single bolt type), can't find it anywhere in my paperwork*oh well*
How many litres of paint (approx) are needed to paint a full mini shell, inc underside, excluding roof, but with shit loads of roll cage etc inside.
Ta,
Rich
Here for the craic..
Supercharged Arden powered
ive got the torque outside, its not as much as you would think, but i cant remember off hand
ah just did a quick look on here, mini13 and british open classic reckon its 50lbft
I bought 4 litres to do my car, ive got a little bit left over (i didnt do my roof though), and put 2 coats everywhere
maybe you could get away with 3? but i wouldnt want to be running out, 3.5L perhaps!!haha
Edited by Nic on 11th May, 2007.
Nics right as usual But...........
if you are doing it in cellulose paint get ..........More!
a few liters,......... it will hurt the back pocket NOW!
but pay you in a few years to come *wink**wink*
as the supply ......& your colour match will dry up in a few months *wink**wink*
OH and dont forget the Thinners suppy for the future *wink*
Turbo Tel
Member #: 588
Delaware, USA
Same here
Bought 4 and have enough left over if anything unfortunate happens..
Terry
If you are doing a cage add about another 2 litres, painting cages is an absolute twat and you will use (READ: waste) a lot of paint to get anywhere near a decent covering on a cage.
Richspec
Member #: 300
Cumbria
Cheers guys, knew i didn't have enough paint, just needed to get an idea how much more, answer=lots :)
On 11th of May, 2007 at 01:16am BENROSS said:
Nics right as usual
unlikely
I think this was talked about a while ago and if my memory serves me correct, then it is not possible to accurately torque up these bolts, since you are compressing a chunk rubber as you do them up, therefore good & tight is all that's required.
They tighten down onto the shoulder of the bolt when the rubbers are compressed, so you should be able to torque them, they will go from easy-ish to do up when compressing rubbers then all of a sudden will go solid when the shoulder hits the subframe.
