Home > Help Needed / General Tech Chat > Running Rich
b12
Member #: 247
Kent/Surrey Borders
ANother oddity ;
Now the engine is up and running in my mini ; With a new Green Fillter and maniflow exhaust ; ( the only mods so far apart from the bleed valve)
it is running very very rich; the tail pipe is filty already
Could this be connected to my other post about running on ?
Shall I just lean it off a bit ;
I will get in on a RR as soon as the intercooler is fitted !
Steve
TurboLessTosser
Get to the RR
What fuel pressure you using? This effects it a fair bit.
Also have you rebuilt the carb? Sometimes the rubber seals on the choke go hard and cause it to run very rich
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
rr it...
you cant lean it off without altering the needle!
alex
AlexF
