| Home > Help Needed / General Tech Chat > Short stroke engine | |||||||
14th May, 2007 at 07:31:15pm
Ive been reading and reading and reading, and there seem to be loads of options available but im unsure what my best option would be.
14th May, 2007 at 07:48:35pm
the SA cranks have 70.2 mm stroke as standard and let you use std A /A+ rods. if you destroke a std crank you can get down to 78.3 or thereabouts. Then you need S rods. If you dont want to skim loads of metal of the top of the block to get the pistons up you need longer rods (custom rods or 970 rods). I am using a SA crank and have skimmed 7 mm of the top of the deck |
14th May, 2007 at 07:49:13pm
you will be better to go with the 1293 option. large bore and short stroke getting nearer over square
14th May, 2007 at 08:07:32pm
you cant seriously call a 1293 over square? :) I have 73,5 mm bore and 70,2 mm stroke. That is oversquare, the 1293 is not. or did you not want oversquare? |
14th May, 2007 at 08:20:05pm
Well I want to get it as sqaure as possible with utilising the parts I already have e.g. using 1293 pistons. etc..Lol
14th May, 2007 at 08:31:47pm
you loose squish, get the pistons all up and use dished pistons. Its no good to run the pistons down the bore... |
14th May, 2007 at 08:39:03pm
I'd have to use 18cc dishes to get the CR any where what I want and they would need valve reliefs cutting out, not sure whether it could be done?
Edited by matty on 14th May, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th May, 2007 at 08:46:13pm
On 14th of May, 2007 at 08:31pm miniminor63 said:
you loose squish, get the pistons all up and use dished pistons. Its no good to run the pistons down the bore... So the theory goes, but Turbo Tim's engine ran the pistons down the bore and that won him the Avon trophy last year. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
14th May, 2007 at 08:49:36pm
everything is possible with boost Edited by miniminor63 on 14th May, 2007. |
14th May, 2007 at 08:58:18pm
you loose squish, get the pistons all up and use dished pistons. Its no good to run the pistons down the bore... So the theory goes, but Turbo Tim's engine ran the pistons down the bore and that won him the Avon trophy last year. Thats what got me thinking its suprising how much I can remember from drunken conversations but forget soo much when soaber..
He was running flat tops aswell, wasn't he? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th May, 2007 at 09:15:33pm
miniminor63 i said getting NEARER! over square
14th May, 2007 at 09:19:57pm
okay Mr Benross, point taken :) |
14th May, 2007 at 10:26:18pm
i should have said ....
14th May, 2007 at 10:33:04pm
matty, a mate of mine is running flat tops (same ones tim had i believe) down the bore, with a std size head and the block skimmed a bit he's running 8:1cr and 160ish banana's @ 15psi. thats on a std stroke and +20 bore though. On 20th Oct, 2015 Tom Fenton said:
14th May, 2007 at 11:16:15pm
Yea just got a pm bud https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
16th May, 2007 at 12:03:40am
Any preferences which is the better rod AEG521 or AEG625 or if there the exactly same?
16th May, 2007 at 12:39:45am
I've been thinking about this since our conversation at the Riv and have decided that I am not happy with the idea of leaving the pistons down the bore.
16th May, 2007 at 01:11:19am
i'm running 8.7:1 on my lump at 12psi for the time being but hopefully i'll have wound it up to around 16/17 before avon park. my advance is quite conservative at the minute though, think my max is 24 degrees on boost. On 20th Oct, 2015 Tom Fenton said:
![]() 725 Posts Member #: 177 Avon Park 2006 Class D Winner Woburn Sands |
16th May, 2007 at 07:27:20am
Yes i do run my pistons down the bore, and yes they are flat too.
16V project underway |
16th May, 2007 at 07:57:36am
On 16th of May, 2007 at 12:03am matty said:
Any preferences which is the better rod AEG521 or AEG625 or if there the exactly same? The 521 and 144 rods are Cooper S and exactly the same. THe 625 however is a Midget rod and is inferior in material quality but still over engineered for our needs. Fit either, no problem. On 13th Jul, 2012 Ben H said:
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
16th May, 2007 at 08:19:50am
if you do go the stroked route, you probably already know this but when using the Con Rods and the stroke you mention, pending on the gearbox casting you will need to die grind a bit out of the gearbox or the endcaps on the rods will catch. i used a GT crank and had it stroked. another lil 2peneth would be to get everything balanced, pistons, rods, crank and flywheel............but that is just me :) Edited by Richie on 16th May, 2007.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
16th May, 2007 at 08:30:16am
he is talking about de stroking, do not need to grind the gearbox casing then...:) |
16th May, 2007 at 11:59:43am
Yeah destroking. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
16th May, 2007 at 12:03:47pm
the flat tops my mates using are the short height ones for long stroke motors, rather than std height flat tops. On 20th Oct, 2015 Tom Fenton said:
16th May, 2007 at 05:42:29pm
Matty, you won't need it down in the low 8s, not with full management.
