Home > Help Needed / General Tech Chat > whats this connection for?
chinlesswonder
Member #: 1192
In the garage......again!!
I have a connection in the up pipe from the turbo, really low down, who knows what it connects to or what i can use it for?, also, where does the pipe coming from the actuator connect to?.
keith
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
Nick
Member #: 154
Midlands
one side of it goes to the actuator, the other side goes the boost solenoid, if you're not using the ECU/solenoid then blank one of them off.
chinlesswonder
Member #: 1192
Saved the day again bud, cheers
keith
Dangerous
Member #: 417
I installed a blind pop rivet in mine
