Home > Help Needed / General Tech Chat > Which Gearbox Rebuild Kit
I will be buying a Gearbox Rebuild kit pretty soon, as Benross has once again offered to help me out! Top Geezer!
Is the Kit below ok??
I have a A+ Box, i already have a Hardened Diff Pin. Im not going straight cut apart from the Drop Gears.
And Should i be buying the later Idler Bearing?
http://www.minispares.com/Product.aspx?kid=37117
http://www.minispares.com/Product.aspx?pid=36278
Mike
I would not bother with the kits. I ordered one but they could never send it as they never had all the parts in stock at one time.
Make a list of the bits you need and give Min-its or others a ring.
Dont waste money on new baulk rings unless the existing ones are shot. Most people that buy a full set find that the box will not turn with them all fitted.
Use the later Torrington idler bearings.
Think very long and hard about a cross pin diff, this really is the weak link.
i would not bother ordering any think yet mike untill you have stripped the box
the lay shaft usually is not worn
and theres a few money saving tips i can give you
heed toms advice
axels right with the baulk rings
Ok Guys, ill hold back then!
Cheers Lads
