Home > Help Needed / General Tech Chat > diff side cover wear with lsd outputs
noticed tonight whilst the covers were off the diff that the pot joint output shafts flanges (LSD) have eaten into the dif side cover a good 1/8"...
is this the norm? I wouldnt have thought...whats caused the side loads on the output shaft?
will post a pic up soon
Joe
never happened to me over the years ,but my good friend Ian Jonson had the same problem,,
1/8 is a lot of chewing, are you sure,
i have a theory, but its a thin one,
carl
spill the beans carl
yeah, thats pretty much how much of the bronze bush has been eaten...
danboy
Member #: 1381
How much work has it done Joey
Regards
Dave
possible cause!
i have seen this on many occasions and i think its caused by hi speed torque cornering
hence you have none on yours carl
No idea what milage its done, hopefully not much, its the box I bought from Avonbar last month (off a turbo challenge car i think??)
it s a jkd mk6 dif i think
Not heard of the bush wearing, Ive run Salisbury for 3 years and had the output retaining washer eat into the aluminium of the side cover.
Paul
pics
and yes it appears i was talking out of my arse with 1/8" but still...
miniminor63
Member #: 672
The oversills police
Oslo, Norway
A tip when using hardy spicer joints on the shafts is to put a inner valve spring inside the hole in the HS joint where the splines to the driveshaft is. Then it will always push that thing away from the sidecover and that wear is avoided:)
