Home > Help Needed / General Tech Chat > Is this any good? (diff pin and planet wheels) - Updated with More Pic's
Anton
Member #: 764
Staffordshire
Ive just busted my first competition diff pin, so i'm pricing up to fix it... I know I really need a 4-pin but money is to tight to run get one atm.. so its going to have to be another competition pin again :(
but upon looking on the MS site i found this:
http://www.minispares.com/Product.aspx?pid=35923
Anyone have any experience of it? It any good, etc?
Edited by Anton on 31st May, 2007.
anton , any chance of a pic of the broken pin ,? what were you doing when it broke ?
thanks robert
Anton
Member #: 764
Staffordshire
pic from the outside..
http://www.minifinity.com/modules/v4bJourn...on/DSC00359.jpg
johnK
Member #: 690
Norfolk
ooh - that hurts
what diff ratio are you running anton?
JK
If Carling made Mini engines
Anton
Member #: 764
Staffordshire
3.1 atm.... Im tempted 2 up that 2 a 3.44 tho...
EYE CHI WOWAH!!!
that is worrying !!!
i presume it span the pin and bent the roll pin and then popped out wilst rolling ,eeek
commiserations anton ,
er i hate to ask ,but ,,,,what power is it at ??
thanks
i have that kit on at the minute cant say any faults to it to be honest, very nicely machined million times better than the standard items
dont know what its like under loads of power i am still running in / at 4 psi but corners nicer than the pos i removed from 998 lump no 'slop' in the output shafts at all (cant describe what i mean very well)
I'm thinking along the same lines as Robert,
the planet has welded itself to the pin and spun it taking out the locating pin, the pin has then worked its way out....bang!
at £50 for that kit, i'd be thinking I may as well go the extra and get a 4 pin, plus it appears the kits not in stock anyway...
If you do go for the kit i'm sure it will be considerably better than the std setup, but 1 thing i'd probably do is replace the locating pin with somthing solid, perhaps tap the diff cage and put a countersunk caphead in? should make it much harder for the pin to spin then.
johnK
Member #: 690
Norfolk
Anton - I really don't want to see you doing that again! - pm sent ref 4 pin and 3.44 cwp
Nick
Member #: 154
Midlands
ant definately get a 4 pin dude, sell your sister if you have to...i'm sure Nic would buy her, lol.
i've got a spare A+ case here if that other one of yours turns out to be an A.
I'm using the bushed planet wheels in my NA 1275 at the moment. I've done a couple of thousand miles on it.
The main problem I had was the diff was very tight on assembly with all the new parts.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Anton ..... unlucky mate .... never had one take the case out though even though I've snapped a few pins!!
Thinking of the time and expense of fixing that I'm sure a 4pin diff would have worked out cheaper!!!
Anton .... is that on your naturally asperated motor (sub 100 bannanas isn't it???) ...... just to frighten robert!!!
OH THANK YOU VERY MUCH !!!!!!*surprised**surprised**blush**crying**crying*
*tongue**tongue**wink**wink*
Edited by robert on 27th May, 2007.
Anton
Member #: 764
Staffordshire
yeah was rollered just bellow 100 a few weeks back with a cracked exhaust manifold... so i'd expect it to be running just on 100 now.
i feel sick
Anton
Member #: 764
Staffordshire
ay.. i know the feeling... when it happend and checked i had not hit anything inthe road.. and it dawned on me what i had just done... sick was a pretty acurate description
andeh
Member #: 97
Near Daventry, midlands
those bushed kits a so far superior to the std ones its untrue, lets not get it confused its no substitute for a x-pin. Second best would be a std diff made up from numerous older diffs, pick the best of the planet gears (start with 998 mini boxes if you can) to reduce slop on a new pin, the slop is where the bloody things wear.
If im completely honest if i had a std diff (i did for a while in my first motor) i'd leave off the beans in the corners and when pulling away (particularly when pulling out of a junction, weve all been there), its the only real way of making the single pin items last.
Edited by andeh on 28th May, 2007.
RogerM
Member #: 1217
Rob ..... I broke a comp pin with a 90 BHP 1275 a few years ago .... ok it was on A008r tyres (in a softer than normal compound) and it was on a really hard drive across the cotswolds ... but it did brake!
Hence why a 4 pin is my min requirement if I'm building a new motor ...
Anton
Member #: 764
Staffordshire
Engine is out and striped.. Thanks to bud666 for pitching up and giving me a hand.
Seems the roll pin has disappeared and let the diff pin come out... the actual diff pin isnt in that bad condition tbo.. will get a pic of that tomorrow.
also looks like the rest of the engine is in good condition and is exactly like i would expect from the miles its done (around 10k for the box, 3kish for the engine)
latest pic of the casing...
RogerM
Member #: 1217
Nice ......
That case looks perfect for what I want ...
Glad there is no damage to the expensive bits!!!
turbo hogster
Member #: 178
stowmaket suffolk
thats a familar site, but the roll pins are the weak point, the only option realey is a 4 pin diff unless you want to shag another gear casing.
the diff pin set up is to marginal for high torque motors realey
Nick
Member #: 154
Midlands
i was expecting carnage inside the box but it all looks fine ish, even the diff pin is hardly marked, no sign of the roll pin though.
luckily the rest of the engines fine though, took the pump apart and its as fresh as the day it went in.
jb weld
Does anyone use these? they got a good write-up by KC last month, showing the wear after grass tracking?
carl talbot
Member #: 1323
Might be of interest to those using std diff pin [assuming this mod will fit in a mini ]
On my Trials diffs [not allowed to use any form of lim. slip diff] where a x-pin diff is not available , i fit a thin tin plate ,eg 20swg , over each end of the diff pin , this is secured with 2off m4/m5 cap heads , or if clearance issues can use countersunk machine screws , tapped and locktited into diff casing either side of the diff pin .
If the planet gears weld onto the diff pin and shear the locating roll pin the diff pin can turn for hours and not wear through the retaining tin plates , Diff pin can't drop out !
Saves a lot of expensive damage .
Hope all the above waffle makes sense?
Carl
