Home > Help Needed / General Tech Chat > Even More Teething Problems ** UPDATE FIXED **
b12
Member #: 247
Kent/Surrey Borders
Took the car out again today ; ( an possible RR session booked for two weeks time )
It really is running filthy rich at the moment ; but when I get the power on ; It just dies ;You know the feeling you get when your electrics are wet ...
Mine wasnt wet ;
DO you all think this is all linked to set up ; Ie needle and Mix and timing etc ?
If you all do then I will let the RR sort it all out ; or is there something else it good be that I should look into b4 the RR session
I have tried a new coil; still have to put in new plugs; leads and sort out the tappets
Steve
Edited by b12 on 3rd Jun, 2004.
TurboLessTosser
could be overfueling, and flooding..?
b12
Member #: 247
Kent/Surrey Borders
dunno ...
could be
I have not tested the regualtor yet though ; but this behaivour was not happening when it was all in the metro ....
TurboLessTosser
Gibbo
Member #: 34
Does this happen at the boost transition point?
If it does, read some of the old posts on checking that the float chamber is being pressurised.
b12
Member #: 247
Kent/Surrey Borders
Ello !!
no it does not happen on at the boost point ; It buzzes up to 7PSI then when she starts zooming along nicely; it starts bogging down ; and spluttering ;
off the revs ; slow it down ; and it still splutters; until I change down a gear then its ok again ...
now I am writing more; it sounds like over fueling doesnt it
S
TurboLessTosser
1380Turboman
Member #: 221
I would bet on over fueling. Mine was doing exaclty the same. I had to lower my fuel pump pressure to 3.5psi at idle. Then all the problems stopped.
b12
Member #: 247
Kent/Surrey Borders
Im going with over fueling ...
When i switch off it runs on and The back of exhaust is black (rich)
gotta be ....
I am going to plumb in a fuel pressure gaugue in the car ; I can use that to set my fuel pressure at idle and should be fun to watch on the road as the boost comes in ...
S
TurboLessTosser
get it on the rollers now now now *wink*
b12
Member #: 247
Kent/Surrey Borders
Altrezia
*smiley*
TurboLessTosser
b12
Member #: 247
Kent/Surrey Borders
bugger bugger bugger
I tried a second earth strap and it still runs like a bitch
RR should be in twop weeks ; but I wanna get my intercooler in b4 then ...
Also getting a fuel pressure gaugue 2morow so i can check that
Ive gone from a nice high to a bit of a low now !!
still gave it a thrashing tonite .... Nice ...
got in my 1275 with a hiff 44 after ... boy it seemed slow !!
S
TurboLessTosser
b12
Member #: 247
Kent/Surrey Borders
wil_h has pointed out a loop hole in my wiring
I am taking the 12v for the dizzy from my coil
as I have a ballast resisitor in place this would mean that my dizzy is only getting about 9v
I wonder if this is why ; when the car is up in 4th gear and underload ;trying to accelarate hard; it coughs and splutters ?
What do you rekon Chaps ?
S
TurboLessTosser
b12
Member #: 247
Kent/Surrey Borders
Soton1310Turbo
thank you
my problem was
"the Rubber Balance pipe. This is actually a ?part-throttle? lean off device, and is also found on some ?economy models? of other SU fitments. This has an accurately sized orifice that is tuned to the standard engine. As soon as any modifications are made, this becomes incorrect, and can cause excessive Lean out under part throttle or gentle acceleration.
I think this was on turboDaves website ( am i right )
anyways CHEERS the i clamped this pipe and the car runs like a dream !!!!
TurboLessTosser
jamesfawcett
Member #: 218
Bingley, West Yorkshire
wont it use alot more fuel without the pipe?
b12
Member #: 247
Kent/Surrey Borders
feebs mate i dunno if it will or not
but at 5psi the little bugger shifted !!
TurboLessTosser
It uses more fuel yes - but only when stat at cruise on the motorway at 50-70mph... Fit a different cam, or change the CR, and it's useless anyway!
