| Home > Wanted > Pre vero flywheel, with pre engaged starter ring gear. | |||||||
2644 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
27th May, 2007 at 03:46:03pm
As title, please.
28th May, 2007 at 11:32:51am
I'm not 100% sure but I believe there was never this combination from the factory. Certainly when I have wanted to use this combination I have always had to create it myself.
28th May, 2007 at 11:54:19am
I believe your correct Roger, I just posted on the off chance someone had one spare.
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
30th May, 2007 at 01:40:44pm
i have a pre verto flywheel pm me if you want it
30th May, 2007 at 04:36:44pm
Which ring gear is fitted?
147 Posts Member #: 814 Advanced Member Utrecht, The Netherlands |
30th May, 2007 at 09:54:00pm
it is possible to use a pre engaged starter on a non verto flywheel without modifying the ring gear, even sounds a bit like a formula 1 car starting.. |
30th May, 2007 at 10:18:16pm
I used the wrong ring gear starter combo once before, by accident, really not keen with the unhealthy sound!
Of course that's because the starter gear makes more noise turning the flywheel round without perfect teeth on the flywheel. I've been running this setup for 60.000 km without any problems, so the "wrong" ring gear doesn't damage the starter that much..
