| Home > Help Needed / General Tech Chat > Turbo flange gasket material | |||||||
28th May, 2007 at 04:28:50pm
What do you aLL think of this gasket sheet to make a turbo exhast flange gasket?? Steel and graphite, sounds OK..
Edited by Turbo Tel on 30th May, 2007. website:- http://www.terryhunt.co.uk
28th May, 2007 at 10:29:36pm
looks like typical steam pipe gasket....
29th May, 2007 at 02:21:46am
I'm using the proper gaskets at the head and T25 flange, this is just for the turbo to downpipe, I was told that a gasket is not needed but since I welded the flange I am not overly confident that it will seal, this gasket material seemed the best bet... Edited by Turbo Tel on 30th May, 2007. website:- http://www.terryhunt.co.uk
29th May, 2007 at 05:46:30pm
It might work down there ok....
29th May, 2007 at 07:29:57pm
Yep,
444 Posts Member #: 2885 Senior Member |
18th Jun, 2009 at 12:05:09am
Hi, similar question, my exhaust flange has wasrped slightly from welding a downpipe to it and i can get 1.7mm graphite 'DIY' gasket, anybody tried it?
18th Jun, 2009 at 08:02:31am
I would just get it faced then you know it is right. http://www.twin-turbo.co.uk
18th Jun, 2009 at 10:25:48am
As above..machine it flat, then no gasket required.
