| Home > Help Needed / General Tech Chat > brake vaccum takeoff bolt | |||||||
30th May, 2007 at 10:10:45pm
can i use the top of this bolt that goes to the brake servo as a takeoff for either a dump valve or turbo boost gauge?, i have noticed it has a plastic x piece inside, not too sure what that does but i can blow and suck air through it
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
30th May, 2007 at 10:14:05pm
Im not 100% but the thing you seeinside is a non return valve?
30th May, 2007 at 10:20:07pm
thought that but its strange i can suck on it (oo err) and blow through it without any resistance 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
30th May, 2007 at 10:35:48pm
It is a non return valve. It is probably shagged. |
30th May, 2007 at 10:37:08pm
Try blowing through it from the manifold end. You'll find it works then.
1st Jun, 2007 at 07:01:31pm
so it will be no good for a takeoff ? surely its just a case of running a drill down it to remove the valve. Why is it there in the first place, the pipe is swaged at the top so looks like it carrys a hose to something. Edited by chinlesswonder on 1st Jun, 2007. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
1st Jun, 2007 at 07:27:07pm
One way v/v is there to stop the turbo pressurising the breather system when on boost.
1st Jun, 2007 at 07:33:53pm
ah, so the cannisters on the engine are plumbed in to this spigot to burn off in the engine?so if i don't plumb the cannisters, i could use it for the boost guage?, or am i talking cock as usual.
1st Jun, 2007 at 07:39:13pm
Got a little brass fitting in mine for the boost gauge
Edited by Dangerous on 1st Jun, 2007.
1st Jun, 2007 at 07:51:02pm
Is yours still using the servo vav pipe, not too clear if you have a servo in thatr pic. also, will it affect the boost gauge reading, could i use it as a trigger for the bov 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
3rd Jun, 2007 at 06:37:10pm
Managed to fit a duel splittter pipe in the centre of the vac bolt, will this be ok for both the bov and the boost gauge? or will they interfere with each others performance
3rd Jun, 2007 at 07:03:51pm
They will be fine together. |
