| Home > Help Needed / General Tech Chat > OT: Midget Clutch, Arno / Steve1275? | |||||||
31st May, 2007 at 10:38:43pm
The clutch on the Midget screams when I select a gear after the car has been sat for a few hours. After the engine is warmed up and I've done a few gear changes the noise goes away.
31st May, 2007 at 11:01:50pm
Spigot bearing in the end of the Crank??
1st Jun, 2007 at 01:52:27am
dito danboy
1st Jun, 2007 at 07:07:48am
My old sprite had an oilite bush in the end of the crank. If these get cooked they dry out and that could give rise to the sort of noise you suggest mate.
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
1st Jun, 2007 at 07:48:19am
Does it scream when holding the clutch out or when you start to let it bite?The former is release bearing,the latter moisture on the plate.If you have to replace the bearing again,get a roller setup from Peter May. 'Where does the engine go?' |
1st Jun, 2007 at 09:27:20pm
It starts screaming when you start to let it bite, but then won't shut up if you push the clutch in all the way.
1st Jun, 2007 at 09:59:52pm
Spigot bearing! Was it new when you replaced the clutch?
Edited by danboy on 1st Jun, 2007. |
2nd Jun, 2007 at 08:32:14pm
If it still screams with your foot off the pedal it's not the spigot bearing,because the shaft bearing and crank are all rotating together then. 'Where does the engine go?' |
2nd Jun, 2007 at 11:00:59pm
Steve1275 that's not what he said in the original post, but if that's the case it's the Fan belt!! If your foot is off the clutch pedal it's not clutch related
2nd Jun, 2007 at 11:13:09pm
I replaced the spigot bush about two years ago, when I first pulled the engine, as the original had disintegrated.
2nd Jun, 2007 at 11:27:40pm
It can only be the release bearing or spigot bearing. My opinion is the spigot bearing but both are an engine out job, so just replace both and have done.
2nd Jun, 2007 at 11:29:21pm
Dam, looks like the engine is coming out again. :( Isambard Kingdom Brunel said:
3rd Jun, 2007 at 07:06:42pm
Rob, be careful to make sure that the spigot bearing is running ture to the crank .... wouldn't be the first one I've seen not to be in there straight!! Every day is a school day ...........
