Home > General Chat > turbo dizzy
n.g.l.
Member #: 181
Chard, Somerset
which is the better of the two? Mk 1 with separate ign. module or Mk2 with ign. module mounted on the dizzy?
both the same *smiley*
tests have been done and results posted sometime in the past and found to be the same.
Pretty sure it was turbodave that did it although i cant be sure.
n.g.l.
Member #: 181
Chard, Somerset
i'm sure i read somewhere the Mk 1 had a better advance curve?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
better more like differnt.... it is only a benfit if it helps your engine!!!
alex
AlexF
Yeah you will of read it somewhere but the tests proved otherwise!
We all thought the same too! *smiley*
TurboHarry
Member #: 115
Austria, near Vienna
I tested both about 2 years ago. The advance curves are exactly the same!!
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
