Home > Help Needed / General Tech Chat > CC or not CC
mini-marauder
Member #: 68
Coventry
Right, ive been seriously hacking at my cyl head, and im still only at 24cc. head looks like VMAX one here but has even more off the side opposite the plug.
didnt really want straighter walled sides, but is this the thing to do?
May have to stick with 24cc.
anyone anymore pics i can use as a guide? Jimster?
R.
Sooperdooperturbocooperexpertengineering!
minimark
Member #: 19
newcastle
mail me i`ve got most head pics
mini-marauder
Member #: 68
Coventry
Cheers Mark. my chambers look bigger than most of thos and im still only at 24cc..... will have to look at some other ways of lowering CR.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Have you lowered the roof of the combustion chamber and re-cut the seats?
alex
AlexF
mini-marauder
Member #: 68
Coventry
No... but that costs money which i havent got spare. hence the reason im trying myself. may take it out a bit more but worried i will hit the water jacket.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Hmm tight budgets and more boost leads to problems...
alex
AlexF
mini-marauder
Member #: 68
Coventry
Lower CR and Higher boost will come in the form of my spare head. will get that convwerted to unleaded and have roof machined out at same time.
At the moment, money is going on DV's, bleed valves, boost gauges etc etc.....
Anyone know what the bore diameter and compressed thickness of a Payen BK450 head gasket is? i was working on 82mm by .9mm (giving 4.75 CC)
if its the above i have 8.8CR.... what highest boost i should safely run? (im using zetec jets too)
EDIT - Aww bugger, thats not right!.... diameter is about 74 and 2.8CC...... = 9.2CR.... bugga!
Ross
Edited by mini-marauder on 3rd Jun, 2004.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Ross... have a play with
http://www.afracing.com/cr.xls
With 8.8:1 I would guess at 10-12 psi... but do you have an intercooler?
Alex
AlexF
mini-marauder
Member #: 68
Coventry
HEY!!... Deck volume! what is it on a bog std Metro turbo lump... i was taking it as zero as im sure pistons were flush. not so sure now!
Sheet is cool BTW.
No intercooler as yet, but is on the shopping list.
I recall a BK450 compressed is 3.9cc - at least that's what i calculated.
mini-marauder
Member #: 68
Coventry
Got 2.8cc from Minispares site. probably wrong.
if deck is 5.25 then my CR @ 24cc chamber vol = 8.00 as below.
just got to find out what it ACTUALY is.... anyone confirm?
Bore 70.61 mm
Stroke 81.4 mm
Gasket Volume 3.80 cc
Ring land Volume 0.5 cc
Piston Volume 12.00 cc
Head Chamber Vol 24 cc
Deck Volume 5.25 cc
Compression Ratio 8.00 :1
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
You need to measure your deck volume...
If I make simialr assunmptions on my engine I end up with a CR of 7:1... without the deck hight and a different gasket this could be a fair bit higher at 8:1.
Alex
AlexF
mini-marauder
Member #: 68
Coventry
OK, but could have done with knowing now as im grinding head. once block is back out of storage, i dont really want grinding grit all over it!!!
Need to get some main and bigend bearings now and do a trial fit.
Deck vol is naff all on std turbo pistons...
As regards the BK450, get a caliper out and measure one, but 1mm thick is 3.9cc, 0.9mm is 3.5cc, 0.8mm is 3.15cc and i'm sure it isn't that thin...
