Home > Technical Chat > reboring
Lone Wolf
Member #: 1092
Yours from the Funny Farm
hey guys
i have a metro turbo engine
i was wondering if after a rebore to 1360 would i need to do anything to maybe increase the compression ratio again?
im planning on running a T2 turbo and not having a lot of boost. maybe around 10-12 psi
thanks
tom
Warning:Stig in Training
The Turbocharger:God's Finest Minute
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
reboring is likely to increase your CR anyway... so you may need to lower it, rather than raise it.
What pistons are you using to get to 1360cc?
Alex
AlexF
1360 is probably minipares/ ketih calver/ Russel engineering pistons.
They do a 73mm piston, that comes out at 1360cc
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
What dish are these pistons?
11cc
http://www.minispares.com/Product.aspx?pid=38633
RogerM
Member #: 1217
interesting.
Lone Wolf
Member #: 1092
what do ya mean roger?
have i missed something?
is 11cc too little dish?
i was thinking maybe 1330 or 1360 cause theres no replacement for displacement and all that
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
there is no substitue for boost however!
Alex
AlexF
RogerM
Member #: 1217
Depends on the CR your aiming at.
For a road motor that is really nice to drive you should try to get the power you want with the minimum amount of boost ...... this isn't the 80s ...lol
vegar
Member #: 189
I wouldent rebore the block more tha I actually needs...
www.shag.no
Lone Wolf
Member #: 1092
this isnt going to be an everyday car
just something to take out on a friday night and scare people
anyone care to suggest a spec?
RogerM
Member #: 1217
Lone Wolf
Member #: 1092
Roger, what CR should i be aiming at?
tbh i havent the faintest idea how all this stuff is interconnected so i dunno about he cr or the boost or any other too techy stuff
i was thinkin around 130 bhp
what do ya suggest for that?
if its your first turbo engine aim for 8.5:1 CR would be my advice
RogerM
Member #: 1217
If your going to run about 130 bhp tops (guess you've chosen that limit so you don't have to go for straight cut gears etc.) then you can go a little higher than Benross suggests ... but I'd use a megajolt to give you spot on ignition control which will help it all hang together.
I am going for low 9s (about 9.2:1 if my sums work out) and blowing 10psi over the top for Candice's build and that should be in the ball park of power you are after.
If you think you might want to go for a bit more power later then follow what Benross suggest as 8.5:1 will allow you to run a bit more boost.
Down side to low compression is poor fuel economy and off boost performance, not really too much of a consideration for a track motor or a weekend warrior but if you hav eto drive it to work everyday, especially across a busy town / city, then it will soon get to be a royal pain in the butt. These, along with the fact that straight cut gears are a complete no-no as far as Candice is concerned for a daily driver (and I have to say I agree) which is what her car will be, are the reasons I am happy to except the power limitations of running a higher CR motor.
Lets face it there isn't going to be much that will hang with a 130bhp turbo Mini in your typical urban sprawl....
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
for 130bhp I would go:
1293cc
9:1 CR
Intercooler
MJ
And you should be there with about 8-10psi.
Alex
AlexF
Lone Wolf
Member #: 1092
thanks a mil guys
that gives me something to aim for
Hedgemonkey
Member #: 360
130hp, that's a lot of bananas for your missus to drive around. Do you expect her to stuff it through the hedge and like the heavy clutch? I would seriously consider putting a block of wood under the accellerator!!!!
Lone Wolf
Member #: 1092
my what??
im 17 mate
i got no worries other than money!
too much trouble them woman things is
*wink*
RogerM
Member #: 1217
I think that was aimed at me ....
Candice has no problems driving my Porsche sideways and to be honest has better car control than 95% of people I know (should do, I tought her well!!!).
If you like I'm sure she will be only too happy to set a lap time at the Combe action day in your car that you'll spend all day trying to beat ... before giving up *wink*
Lone Wolf
Member #: 1092
woops
soz mate
