Home > Beginners Tech > return fuel line
mini_jim
Member #: 1702
kent
hey guys,
i just read somwhere a guy talking about his new conversion he is about to start and read that he has bought 8mm copper fuel line for the return line.
have a made a realy silly mistake as i have bought braided line for the return pipe.
should i have bought copper line instead ?
cheers,
jim..
0 -- CASUALTY IN 5 SECONDS
braided hose is fine, as long as the bore is big enough, what size is it?
mini_jim
Member #: 1702
kent
its 8mm
jim..
Kean
Member #: 341
aka T2clubby
South Staffs
No thats fine Jim, should work no probs at all
yes 8mm should be fine
But remember guys, 8mm copper line is quite a lot bigger than 8mm braided hose.
Turbo Shed
Member #: 30
Epsom, Surrey
nope. there both 8mm. otherwise you should have put "10mm copper is bigger than 8mm braided.lol
as long as the both are internal diameter then i would have put the copper pipe as having the smaller OD
mini_jim
Member #: 1702
kent
thanks guys thats top.
Jim..
Sure? *wink*
Badger
Member #: 1488
Methinks copper pipe has the thinnest wall thickness as well. Not sure, may have to do some measuring lol :)
Edited by Badger on 6th Jun, 2007.
There is no sense crying over every mistake- you just keep on trying til you run out of cake.
chinlesswonder
Member #: 1192
In the garage......again!!
does the feed back have to go in the top of the tank so that the returned fuel 'pours' into the tank unrestricted or can it really be T into the supply before the pump, i don't really see that working properly as it will stop the flow return although i know that people on here have done it, i'm going to be attempting this this week and just need it clarifying.
keith
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
'T'ing into the low pressure (tank) side of the pump with the return has been shown to work fine.
This is how I plan to do mine on the road car, although the hillclimber returns to the tank.
chinlesswonder
Member #: 1192
cheers wil, big help as usual.
keith
redwing
Member #: 1574
Malta
Mine returns to the top of the tank - works fine for me. Just remember to purge the tank before welding.
