Home > Help Needed / General Tech Chat > treaded oil galley plugs? where do i get some
clubminiflip
Member #: 54
nr coventry
i need to get some oil galley plugs, i need threaded ones in the size below, any ideas cheaps
14mm x metric 1.25mm
Edited by clubminiflip on 6th Jun, 2007.
clubminiflip
Member #: 54
nr coventry
how do chaps, i went to my local place roday, they are called kebrell in coventry, they only do nuts bolts washers etc, its a uk company & they do all sizes & some obscure stuff, i found some plugs for the oil galley ways but they are about 3 threads too long, whats my best method of cutting them,
oh yeah, i know this is basics but how many galley plugs are there i can only find two, sorry it is a muppet question, i'm shattard though! crap excause i know hehe *tongue*
Kean
Member #: 341
aka T2clubby
South Staffs
You need 2, one either end of the main gallery.
If they are a grub screw style allen head type, you can just cut them down to suit with a hacksaw
what you need is 4 X taperd 1/4" BSP
allen socket blanking plugs and tap,
2nd tap
use a 11.5 mm drill extract the plugs easy they fall out, now tap the hole its a shade oversize but leaves well enough meat on the threads too make a perfect seal use some thread sealing compound when its time to fit them
also you need 2 X taperd plugs the same as above 1/8" BSP plugs this time and tap
I got mine from a vauxhall main dealer, there are oil gallery or water gallery plugs on a nova. Fitted a treat to my block.
