Home > Help Needed / General Tech Chat > valve springs (FAO TDave)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
What springs do I need with 1.5:1 rockers?
I haven't yet tired fitting my high lift rockers, but I expect there to be coil bind problems....
Whats the deal?
Alex
AlexF
Get the minispares li-lift springs and you won't have a problem with they typical cams we run.
Available in two pundage - 180 and 240 i recall... Take your pick!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
180 it is then... I don't rev mine past 5000 rpm anyway :p
Thanks D!
Alex
AlexF
yep, 180 is all i went for... not sure about the effect of backpressure in the exhaust, and boost pressure in the inlet trying to open the valves (hence reducing the 'poundage' of the springs however - we'll have to see on that one!
TurboHarry
Member #: 115
Austria, near Vienna
I am using exactly this springs with 1,5 rockers and never had any problems with it! (max. revs I am using: 6500)
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
