| Home > Help Needed / General Tech Chat > measuring CR | |||||||
146 Posts Member #: 1092 Advanced Member Yours from the Funny Farm |
8th Jun, 2007 at 10:16:03pm
what to use?
Warning:Stig in Training
8th Jun, 2007 at 10:32:26pm
3 in 1 will be fine. For example if you measure a litre of 20/50 and a litre of 3 in 1 they're still the same volume regardless of viscocity, or you could use parrafin etc |
8th Jun, 2007 at 11:02:36pm
Personally I'd use some thing with a thinner viscosity as 20/50 leaves a very thick film inside the syringe which will effect your measurements, then if you're that serious you wouldn't be using a syringe. Isambard Kingdom Brunel said:
43 Posts Member #: 1124 Member Surrey |
8th Jun, 2007 at 11:44:39pm
A burette is only £8-10 on eBay and will make light work of the task. |
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
8th Jun, 2007 at 11:49:02pm
i could get a large number of medical syringes with the measurement in mls on if they'd be any good for the task chaps! i'll have to check the size of the tip so you can have good control of drwing or squirting the oil or other liquid! SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
9th Jun, 2007 at 12:15:00am
syringe is the way forward...
AlexF |
9th Jun, 2007 at 08:33:08am
On 8th of Jun, 2007 at 11:02pm British Open Classic said:
Personally I'd use some thing with a thinner viscosity as 20/50 leaves a very thick film inside the syringe which will effect your measurements, then if you're that serious you wouldn't be using a syringe. LOL ! i didn't actually mean use 20/50, i was just meaning a volume is a volume, regardless of oil thickness.
As said by others syringes are ideal, that's what i use. |
9th Jun, 2007 at 11:46:05am
thanks guys
9th Jun, 2007 at 01:55:54pm
On 9th of Jun, 2007 at 11:46am Turbo Tom Take Two said:
thanks guys if the syringe is in mls how do i convert it to cc? cant find my conversion chart! 1ml is 1cc Isambard Kingdom Brunel said:
9th Jun, 2007 at 01:58:01pm
On 9th of Jun, 2007 at 12:15am AlexF2003 said:
and if you use ATF its really easy to see ![]() True but it smell foul. Isambard Kingdom Brunel said:
9th Jun, 2007 at 04:16:44pm
ah
9th Jun, 2007 at 04:28:31pm
ATF = Automatic Transmission Fluid
9th Jun, 2007 at 05:32:25pm
atf doesnt smell foul, normal gear oil does kinda a mix between vinegar and sweat. turbo 16v k-series 11.9@118.9 :)
10th Jun, 2007 at 07:49:51am
trans fluid would be good bit thicker than parafin, just go to the vets and get a 35 mm syringe for a couple of quid. always looking for them bigger bunches of bannanas |
