Home > Help Needed / General Tech Chat > best clock cleaning methods needed
clubminiflip
Member #: 54
nr coventry
i wwant to clean my block inside&out as best as possible at home, what do you chaps recommend?
cheers all
I use a steam cleaner, but a large industrial one, I bet a pressure washer would do a simular job. You can also use brick acid, avaible from all builders merchants. If not then good old petrol does a good job.
Lone Wolf
Member #: 1092
Yours from the Funny Farm
i heard cellulose thinner was great for the task
or paraffin
Warning:Stig in Training
The Turbocharger:God's Finest Minute
clubminiflip
Member #: 54
nr coventry
i have has the block machined all the threads checked, threaded oil galley plugs & i want to give it a good clean to make sure theres no swarf or lil metal bits before i locktight my galley plugs in place & paint the block, i'm just trying to be super clean with it!
i have brick acid, would i dilute it a bit jimster? i also have a pressure washer & a stand i can mount the block on, i have a few pipes to stick in a few holes in the thing too!
i have thinners n parrafin too! gotta have this stuff about! it all smells so nice *happy* hehe
Edited by clubminiflip on 9th Jun, 2007.
I usually get mine acid dipped then hot bathed at my local engineering firm. It only cost me 25 nicker a time! And there fookin clean after, gets all old paint off!
clubminiflip
Member #: 54
nr coventry
how do i go about cleaning the oil galley ways???? i want to make sure they are crud free before locking my threaded galley plugs in!
there is only 2 galley plugs on the 998 aint there? hmmm
the timing side is the dirty-ist! lots of old gasket stuck on the block really hard!
theres oilways all over it it how do i know they're clean? i've got some spraygun brushes to poke about hehe
