Home > Technical Chat > update on pinking
turbo tro
Member #: 1651
cornwall
so yeah, turns out the pinking was mainly caused by one of the metal rings in the head gasket poking into the bore, thus heating up etc etc
anyway got that all sorted, havent had time to take it to rolling road:)
yet it still drives fine apart from.......
with the twin stage boost removed car missfires on boost!!!
leave it connected and it missfires a bit on low boost and then is perfect after 4000rpm????
any idea's?
thanx
spark too weak, just solved this problem myself
tbh it could be a number of things that causing ur weak spark but i wont be the same i my reason (well i dont think so lol) worn points... they seem to eat them selves in like 300 mile lol
what ignition system you have standard or mjlj?
Edited by Brett on 11th Jun, 2007.
turbo tro
Member #: 1651
cornwall
could be that.....ill check it out!
its running a standard ignition.
use the search facility
search for turbo daves T peice trick *wink*
yeah this is great little trick, i tried this but this wasnt the problem for me was the points gap lol but i left the carb with this setup because it looks neater with all the pipes going some where in stead of out the carb to an ugly stop lol
What oil you running in dash pot, you many find if it misses as it's coming on boost, you need a thicker oil in there.
Dashpots???. whats one of those then,
