| Home > Help Needed / General Tech Chat > Respraying | |||||||
![]() 199 Posts Member #: 1277 Advanced Member Portsmouth |
9th Jun, 2007 at 03:58:38pm
I've been considering having ago at respraying my car myself with my Dad who has some experience of respraying. I've been in touch with a Company called carpaint.co.uk and they have given me a estimate on the paints that i will need.
9th Jun, 2007 at 04:21:46pm
Seems reasonable, you can spray a car with less, I probably wouldn't use that my primer that said when I sprayed the MG I ran out of primer half way through the car and had to do a made run to get some more.
9th Jun, 2007 at 04:35:34pm
Would of thought you need half the amount of paint. Don't forget, with thinners/hardener it will double up the paint anyway. I use 600/800 grit for primer. Need plenty of 1500/2000 for those odd runs & between top coats On 19th Jan, 2010 wil_h said:
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
9th Jun, 2007 at 10:01:52pm
mind i went to buy some paint tuther day and was told to fek off, unless you are a registered business they will not sell 2pac or cellulose paint to you, you got to have an approved oven now :(:(;( and to make sure you order the paint and they deliver it to you.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
9th Jun, 2007 at 10:04:32pm
F***ers! So symthetic only then! Those hangers are going to be flowing! On 19th Jan, 2010 wil_h said:
9th Jun, 2007 at 10:16:36pm
Jawel, who I get my paint from are still selling the stuff online:
10th Jun, 2007 at 07:42:03pm
Thanks for the advice guys. Wet&Dry is no prob i can pinch aload of that from work. |
10th Jun, 2007 at 08:36:24pm
easy, Ure not alowed VW Gelb (yellow) psml !!!
