| Home > Help Needed / General Tech Chat > gearbox | |||||||
96 Posts Member #: 251 Advanced Member Nottingham UK |
3rd Jun, 2004 at 04:23:54pm
hi guys, |
3rd Jun, 2004 at 04:42:12pm
Sounds to me like you have a clutch problem...
AlexF |
3rd Jun, 2004 at 06:25:57pm
sounds clutch related...
3rd Jun, 2004 at 06:49:03pm
Can i just ask, just to recheck.
3rd Jun, 2004 at 07:00:21pm
I have replaced the arm itself for a new one, all pins have been replaced with brand new ones, the clutch plate has been renewed, as have all the pipework and slave.
3rd Jun, 2004 at 07:01:31pm
forgot to mention it is all verto metro turbo clutch |
3rd Jun, 2004 at 08:50:44pm
long arm = non verto
AlexF |
3rd Jun, 2004 at 10:15:09pm
yeah but can you swap the arms over without changing the flywheel housing or clutch??? Will be more responsive with the shorter arm i would have thought. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
3rd Jun, 2004 at 10:58:09pm
Nope, you need the right arm for the right clutch otherwise it dont work properly!
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
3rd Jun, 2004 at 11:07:49pm
i have a verto clutch and small arm
TurboLessTosser |
4th Jun, 2004 at 02:05:08am
the turbo engine i bought had a long arm, i just swaped it for the short arm off me mini and it all works fine, didn't bother swapping the covers etc over, just used the mini slave and short arm. On 20th Oct, 2015 Tom Fenton said:
4th Jun, 2004 at 09:29:27am
b12, the non-verto clutch can take more abuse, not the arm, the arm is needed to get the correct throw/leverage etc.
4th Jun, 2004 at 11:30:06am
ALL standard turbo engines had the verto as std - i'm sure of that... On 17th Nov, 2014 Tom Fenton said:
4th Jun, 2004 at 11:38:10am
so am i but nobody took any notice of what i said! lol! |
4th Jun, 2004 at 12:35:22pm
So have we all decided that it is a clutch problem? If so what do you think is causing it? I have heard rumours that the mini lockhead master cylinder is not upto operating the verto clutch, any suggestions?
4th Jun, 2004 at 12:47:02pm
Same master cyl was used on verto and pre-verto minis, so whoever told you that - i suggest you ignore any future 'clutch' advice from them. On 17th Nov, 2014 Tom Fenton said:
4th Jun, 2004 at 01:00:16pm
Going off everything you've said - i reckon the primary gear is sticking to the crank. Easy check - Jack up one of the front wheels so it is few cm off the ground. Put the gearbox into 4th. Get an assistant to sit in the mini, with his foot perched on the pedal (not pressing it), whilst you grip the raised wheel and try turning it with all your might.
4th Jun, 2004 at 01:51:36pm
but dave when I changed the box I cracked the flywheel housing (flywheel hard to remove) so had to replace it. I cleaned and checked the primary gear when it went back on seemed fine.
4th Jun, 2004 at 04:09:51pm
Sliping causes problems with disengaging!
AlexF |
4th Jun, 2004 at 05:51:30pm
I mean the whole surround that bolts to the gearbox and the block and the bit that the primary gear is sandwiched between
4th Jun, 2004 at 10:04:45pm
Do the check i told you...
5th Jun, 2004 at 01:36:36am
WELL, i have just compared the arm i took off my later metro turbo engine (cable operated) and it is neither a long or short arm, it is infact a MEDIUM ARM! it also has the wrong top to it, it wont use the arm that is found on normal mini slave cylinders. Im just going to have to try it with the 998's shorter-than-the-short-turboarm arm and see how it works i suppose. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
5th Jun, 2004 at 10:12:37am
Feebs, it's still the 'short arm. Trust us! On 17th Nov, 2014 Tom Fenton said:
