| Home > Help Needed / General Tech Chat > Checking headlamp alignment | |||||||
928 Posts Member #: 65 Post Whore South Yorkshire |
11th Jun, 2007 at 09:07:02am
Hi
11th Jun, 2007 at 12:46:09pm
I always do mine up against a garage. I get a car I know the lights are OK and mark the pattern on the door (well a piece of card on the door). Then get the car with the lights I want to adjust and get them close to what I marked. The MOT test is quite noddy so long as they are in the right ball park it will be fine.
http://www.twin-turbo.co.uk
11th Jun, 2007 at 01:04:03pm
It gives the exact height and distance you check them from in the haynes (if your talking about a mini)? :)
11th Jun, 2007 at 01:16:02pm
Didn't realise the info was in the haynes book :) |
11th Jun, 2007 at 01:21:18pm
I didn't realise it was in the haynes book either. Like I say though there is a big window of acceptible aligned lights, so long as it is close it will be fine. http://www.twin-turbo.co.uk
11th Jun, 2007 at 01:23:42pm
I'm going to try your idea first Ben as it seems the simplest way of getting it close. Now why didn't I think of that... :)
![]() 232 Posts Member #: 1197 Senior Member Dublin Ireland |
11th Jun, 2007 at 02:50:54pm
Over here our National Car Test or NCT (basically a MOT) its a failure if your lights are out in the slightest... they love failing you for stupid things like slight headlight alignment and windscreen washer not hitting the windscreen!!!... its basically revenue for the government... its a nightmare... id love to be able to get away with a ball park figure but that would cast me €50 for a re-test... bloody NCT (bitter am I?)
11th Jun, 2007 at 03:59:37pm
As Ben says, as long as the headlights aren't pointing at the sky or floor then generally you'll be OK.
11th Jun, 2007 at 05:55:15pm
any DECENT mot station shouldnt mind givin your headlamps a twiddle for you. if you think there out leave the rings off so the person can adjust them accordingly no longer a series, but still 1.3 turbo.
11th Jun, 2007 at 05:55:58pm
I've found that headlight alighment is often done for free at the test anyway as long as its easy to do, i.e. all the bits in good nick |
11th Jun, 2007 at 10:27:13pm
Well they don't seem too bad, which is just as well as I can't be arsed to do any more now. MOT wednesday so we shall see.....
